Discussion in "PIC Microcontroller Discussion" started by    vohsty    Nov 13, 2013.
Wed Dec 18 2013, 07:52 am
Thanx so much for your help
I did as you instructed but am still getting errors .I dont know what could be the problem
Fri Jan 03 2014, 07:05 pm
i can't find pic.h file
while i am compiling this project these errors occur:
Debug build of project `D:\IDT\MPLAB PROJECT\IDTPM.mcp' started.
Language tool versions: MPASMWIN.exe v5.49, mplink.exe v4.47, mplib.exe v4.47
Preprocessor symbol `__DEBUG' is defined.
Fri Jan 03 17:03:12 2014
Clean: Deleting intermediary and output files.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\main.p1" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\main.p1" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.cof" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.hex" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.sym" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.map" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.hxl" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\startup.lst" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\startup.rlf" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\doprnt.p1" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\doprnt.pre" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.obj" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.lst" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.rlf" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDTPM.sdb" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.cof" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.hex" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.sym" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.map" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.hxl" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\startup.lst" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\startup.rlf" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\doprnt.p1" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\doprnt.pre" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.obj" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.lst" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.rlf" doesn't exist.
Clean Warning: File "D:\1INDUSTRIAL DOMESTIC TIMER PROJECT\IDT\MPLAB PROJECT\IDTPM.sdb" doesn't exist.
Clean: Deleted file "D:\IDT\MPLAB PROJECT\IDTPM.mcs".
Clean: Done.
Skipping file. There is no tool to process the file with the given suffix.
Halting build on first failure as requested.
Debug build of project `D:\IDT\MPLAB PROJECT\IDTPM.mcp' failed.
BUILD FAILED
please help me
my compiler is mplab ide 8.90
Sat Jan 04 2014, 01:54 am
shahinsoft
This project is written for the Hi-Tech C compiler.
It will need converting to compile with any other compiler.
Converting will be difficult and probably not worth the effort.
Either get a copy of Hi-Tech C compiler or choose another project written for
the compiler you have.
 shahinsoft like this.
Sat Jan 04 2014, 01:01 pm
tanks for replay,
was this project written in hi-tech or mplab?
which version of hi-tech do i have to use without any changes in the source of program?
Mon Jan 06 2014, 02:53 am
help me please
Hi all
I made the above mentioned project but when i put it on i only get a black line on the first row. I have tryed using different LCDs but i get the same results. please help me.I have attached pictures of my circuit
i cannot make hex file
Mon Jan 06 2014, 03:42 am
shahinsoft
In main.c it says ...
COMPILER : HI-TECH PIC C COMPILER 9.60 IN PRO MODE
Here the HI-TECH compiler is used as a plugin for MPLAB, so you need both.
Please don't ask why people use MPLAB/ compiler combinations, I don't know
I don't see your diagram, try attaching it as a zip file.
