Discussion in "PIC Microcontroller Discussion" started by    nicholastyc    Jun 5, 2008.
Thu Jun 05 2008, 12:22 pm
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to MPLAB ICD 2
Target Device PIC12F629 found, revision = Rev 0x10
ICDWarn0044: Target has an invalid calibration memory value (0x3FFF). Continue?
ICD0200: Operation Aborted (Warning 43).
MPLAB ICD 2 Ready
Having this problem when trying to program the piC12F629 !
Help... i successfully programmed 1 of my same pic, but later on i used another pic, when i wan to program it it pops up """"ICDWarn0044: Target has an invalid calibration memory value (0x3FFF). Continue?"""""
then i put back my another pic, its still the same although i tried it with my 1st pic which was successful, its now also have this warning...
any help is very much appreaciated.
Fri Jun 06 2008, 05:18 am
try updating the firmware of ICD2.
Fri Jun 06 2008, 09:42 am
hi Ajay, i already have the most updated firmware. I did nothing wrong , and why when i trying to programme the chip its will pop up this warning!
I am trying to program it for the LED dimmer i made the programme for...now wanted to test on it...but cant programme... =(
Tue Jun 10 2008, 06:08 am
i need help!!
Wed Jun 11 2008, 03:59 am
PIC12F629 is not supported by the ICD2. Also most of the 12-bit instruction targets are not supported by ICD2. So you are getting this error. try replacing it with some other 16F IC and see if problem presist.
 nicholastyc like this.
Wed Jun 11 2008, 05:43 am
i will try to update you for the result later..if i got time! thanks
Thu Jun 12 2008, 09:34 am
hi Ajay, i programmed my pic12f629 with pickit2 , but the programme doesnot work at all...i tried to make a simple blinking program..it still doesnot work...
i will post the normal turn on led program, i simulated it in mplab sim, it does work to turn on the output!
Thu Jun 12 2008, 09:36 am
ERRORLEVEL -302 ;remove message about using proper bank
#include <p12f629.inc>
__CONFIG    _MCLRE_OFF & _CP_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT
START
	ORG	0x000
	nop
	nop
	nop
	nop
	nop
	nop
	BCF	STATUS,RP0;
	CLRF	GPIO;
	MOVLW	0x07	;
	MOVWF	CMCON	;
	BSF	STATUS,RP0	;
	movlw     b'10000110'	;
	movwf     OPTION_REG	;
	CALL	0x3FF;
	MOVWF	OSCCAL;
	MOVLW 0x08;
	MOVWF TRISIO;
	BCF	STATUS,RP0;
	BCF	STATUS,C;
	MOVLW	0x08;
	MOVWF	GPIO;
LOOP
	bsf GPIO,0
	bcf GPIO,1
	bsf GPIO,2
	goto LOOP
	org	0x3ff
	movlw	0x20
end
there is no ; between _MCLRE_OFF & _CP_OFF in my code...why when i attach, it appears...
[ Edited Thu Jun 12 2008, 09:40 am ]
Thu Jun 12 2008, 11:57 am
;***Title:Led Light Dimmer VERSION 2*********
;*Author:YC THAM*****************************
;**Date:12/6/2008****************************
	 __CONFIG   	_CP_OFF & _MCLRE_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _BODEN_OFF & _CPD_OFF &_PWRTE_OFF
ORIGINAL_PWM	EQU	H'0020'
COUNT50	EQU	H'0021'
TEMP	EQU	H'0022'
A11	EQU	H'0023'
A21	EQU	H'0024'
GPIO EQU H'0005'
TRISIO	EQU	H'0085'
;******MAIN********
	ORG	0x000
	BCF	STATUS,RP0; bank 0
	CLRF	GPIO;	clear gpio
	MOVLW	07h	;	set to digital I/O
	MOVWF	CMCON	;
	BSF	STATUS,RP0	;	bank 1
	CALL	3FFh;	calibrate the internal oscillator
	MOVWF	OSCCAL;
	MOVLW H'0038';	set the gp3,4,5 as input, gp0,1,2 as output
	MOVWF TRISIO;
	BCF	STATUS,5;bank 0
	BCF	STATUS,C;clear carry flag
START
	BTFSS	GPIO,3		; wait for On/OFF switch input
	GOTO	START;	loop for input
	CALL	PREVIOUS	;restore previous saved PWM
	GOTO	INITIAL_PWM	;go to pwm output loop
INITIAL_PWM
	MOVLW	0x38	; set 0x38input
	MOVWF	GPIO	;
RESTART_PWM
	MOVF	ORIGINAL_PWM,w	; move original_pwm register data to w
	MOVWF	TEMP	;move w to temp register
	BSF	GPIO,0	;turn on output gp0, cool white, HI
	BTFSS	GPIO,1	;check for gp1 condition
	CALL	DELAY	;delay phase shift
	BSF	GPIO,1	;turn on output gp1, warm white, HI
	BTFSS	GPIO,2	;chec for gp2 condition
	BSF	GPIO,2	;turn on output gp2, amber, HI
	MOVLW	d'255';test on the pwm condition
	ADDWF	ORIGINAL_PWM,0;prevent loop on 0 pwm
	BTFSS	STATUS,C;if pwm cycle >
0 , loop for the cycles time
	GOTO	LOOP1;skip cycle count loop
	BCF	STATUS,C; clear carry flag
	GOTO	LOOP0;goto cycle count loop
LOOP0
	DECFSZ	TEMP,1		;cycle count HI loop
	GOTO	LOOP0		;
LOOP1
	MOVLW	d'255'		;total possible cycles, 255
	MOVWF	TEMP		;move to temp register for counter loop
	MOVF	ORIGINAL_PWM,w	;move original pwm to w for sub
	SUBWF	TEMP,1		;sub temp with original pwm
	BCF	GPIO,0		;turn gp0 to low
	BTFSC	GPIO,1		;check for gp1 condition
	BCF	GPIO,1		;turn gp1 to low
	BTFSC	GPIO,2		;check for gp2 condition
	BCF	GPIO,2		;turn gp2 to low
	BCF	STATUS,C	;clear carry flag
	MOVLW	d'255';test on pwm condition
	ADDWF	TEMP,0;prevent loop on 0 pwm
0 loop for cycles time
	GOTO LOOP3;skip loop
LOOP2
	DECFSZ	TEMP,1	;loop for cycle count
	GOTO	LOOP2		;
LOOP3
	BTFSS	GPIO,3		;check on switch on/off
	GOTO	START		;back to start if off, continue if on
	BTFSC	GPIO,4		;check for the new pwm cycle changes
	CALL	SHAFT_0		;increase/decrease on pwm cycle
	GOTO	RESTART_PWM	;continue loop for the current condition
;** SUB-ROUTINE*******************************
PREVIOUS:
	BSF	STATUS,5	; bank1
	MOVLW	0x10;eeprom address for saving data
	MOVWF	EEADR;go to address above 0x10
	BSF	EECON1,RD	;read data in address
	MOVF	EEDATA,w	;recall data to w register
	BCF	STATUS,5;bank0
	MOVWF	ORIGINAL_PWM;save to original_pwm register
	RETURN
;**SAVE PWM IN EEPROM********************
SAVE_PWM:
	BSF	STATUS,5; bank 1
	MOVLW	0x10;address to save data
	MOVWF	EEADR;go to addr 0x10
	MOVF	ORIGINAL_PWM,w	;move data on original_pwm to w
	MOVWF	EEDATA;send the data to eeprom
	BSF	EECON1,WREN	;write enable
	BCF	INTCON,GIE	;clear interrupt
	MOVLW	H'0055'	;<eeprom write sequence
	MOVWF	EECON2	;<
	MOVLW	H'00AA' ;<
	MOVWF	EECON2	;<
	BSF	EECON1,WR	;write in progress
LOOP_WR
	BTFSC	EECON1,WR; test for write process complete>
	GOTO	LOOP_WR;if not complete loop till complete to ensure write successfully
	BSF	INTCON,GIE	;enable interrupt
	BCF	EECON1, WREN;disable write
	BCF	STATUS,5;bank 0
	RETURN
;****DELAY******************************************
DELAY:
	MOVLW	d'50'; number of phase shifting loop
	MOVWF	COUNT50;
COUNT
	DECFSZ	COUNT50,1; loop for 50 cycles
	GOTO	COUNT;
	RETURN
;**DIRECTION***********************************
SHAFT_0:
	CLRF	A11		;clear A11 register
	CLRF	A21		;clear A21 register
	BTFSC	GPIO,4		;check on gp4
	GOTO	SAVEBIT_A11	;goto gp4=1 1st bit
	GOTO	SAVEBIT_A10	;goto gp4=0
SHAFT_1
	BTFSC	GPIO,5		;check on gp5
	GOTO	SAVEBIT_B11	;goto gp5=1 2nd bit
	GOTO	SAVEBIT_B10	;goto gp5=0
SHAFT_2
	GOTO	SAVEBIT_A21	;goto gp4=1 3rd bit
	GOTO	SAVEBIT_A20	;goto gp4=0
SHAFT_3
	GOTO	SAVEBIT_B21	;goto gp5=1 4th bit
	GOTO	SAVEBIT_B20	;goto gp5=0
SAVEBIT_A11
	MOVLW	b'00000001'	;gp4=1 1st bit =1
	MOVWF	A11		;move to register A11
	RLF	A11,1		;rotate left to make 4bit table check up!
	GOTO	SHAFT_1		;back to 2nd bit check
SAVEBIT_A10
	MOVLW	b'00000000'	;gp4=0 1st bit =0
SAVEBIT_B11
	MOVLW	b'00000001'	;gp5=1 2nd bit =1
	IORWF	A11,1		;inclusive or on A11 1st bit , result <00000011>
/<00000001>
	RLF	A11,1		;rotate left to make 4 bit table check up
	RLF A11,1		;rotate again to become 4bit
	GOTO	SHAFT_2		;back to 3rd bit check
SAVEBIT_B10
	MOVLW	b'00000000'	;gp5=0 2rd bit =0
	IORWF	A11,1		;inclusive or on A11 1stbit  result <00000000>
/<00000010>
SAVEBIT_A21
	MOVLW	b'00000001'	;gp4=1 3rd bit =1
	MOVWF	A21		;move to register A21
	RLF	A21,1		;rotate left to make 4bit table check up
	GOTO	SHAFT_3		;back to 4th bit check
SAVEBIT_A20
	MOVLW	b'00000000'	;gp4=0 3rd bit =0
	RLF	A21,1		;rotate left again
SAVEBIT_B21
	MOVLW	b'00000001'	;gp5=1 4th bit = 1
	IORWF	A21,0		;inclusive or A21 3rd bit
	IORWF	A11,0		;inclusive or with A11 to make up 4th bit
	GOTO	DIRECTION	; check on direction
SAVEBIT_B20
	MOVLW	b'00000000'	; gp5=1 4th bit =1
	IORWF	A11,0		;IOR with A11 to make up 4th bit
	GOTO	DIRECTION	;check for direction
DIRECTION
	CALL	TABLE_1		;direction look up table
ANTI_CLOCKWISE
	DECF	ORIGINAL_PWM,f	; anti-clockwise means decrease on pwm cycle
	MOVLW	d'255'; to prevent decrease more than 0 cycle condition, turn to 255 cycle
	SUBWF	ORIGINAL_PWM,0; sub original_pwm
	BTFSC	STATUS,C; check on carry flag if cycle >
0 , carry appears
	GOTO	RELOADZERO; if it is 0, reload zero to original_pwm register
	GOTO	NORMAL;if not, continue to save
RELOADZERO
	MOVLW	d'0'; load 0 to pwm due to over decrease happened
	MOVWF	ORIGINAL_PWM; move to register
	GOTO	NORMAL;continue to save pwm
NORMAL
	CALL	SAVE_PWM	; call save pwm routine to save pwm data for recall on start up
 	GOTO	RESTART_PWM	;return from save and continue to generate pwm signal
CLOCKWISE
	MOVLW	d'1'; clockwise means increase on pwm cycle
	ADDWF	ORIGINAL_PWM,0; add to the register to prevent over increment happned(more than 255)
	BTFSC	STATUS,C;it will turn to 0 cycle if over increment
	GOTO	RELOAD255; reload 255 cycle
	INCF	ORIGINAL_PWM,f	;increase pwm if no over increment condition happened
RELOAD255
	MOVLW	d'255'; load 255 to resigter due to over increment to 0 in w register
	MOVWF	ORIGINAL_PWM; move to resigter
	RETURN
;**** DIRECTION TABLE****************************
TABLE_1:
	ADDWF	PCL,1	; add the result to pc, result is from 4th bit generated
	GOTO	RESTART_PWM	; no increment nor decrement
	GOTO	ANTI_CLOCKWISE	; decrease on pwm
	GOTO	CLOCKWISE	;increase on pwm
	GOTO	RESTART_PWM	;
	GOTO	CLOCKWISE	;
	GOTO	RESTART_PWM	;
	GOTO	RESTART_PWM	;
	GOTO	RESTART_PWM	;
	GOTO	RESTART_PWM	;
	GOTO	CLOCKWISE	;
	GOTO	RESTART_PWM	;
	GOTO	CLOCKWISE	;
	GOTO	RESTART_PWM	;
	RETURN
	END
Thu Jun 12 2008, 11:59 am
hi Ajay, i am really scratching my head, i already programmed my code above to my pic...i tested my code on MPLAB SIM, it worked totally fine with what i expected.
But it dont work after i programmed the code into pic...
wat;s the problem with setting??????thanks!
StephenHauct
Sat Apr 27 2024, 09:38 am
Adamsaf
Sat Apr 27 2024, 07:12 am
