problem is sending sms with 8051 by siemens C55
Wed Apr 23 2008, 08:40 am
hi friends.
I am trying to send sms with 8051(89c51rc2)and siemens C55.But I failed.I dont know why.When I try to send sms,cellphone turns off.
My schematic and C code here.where is my mistake.I dont know.
Also I can send sms by hyperterminal with data cable.And I simulated it by proteus succesfully.And it is project to pass the class.Plz help me firends.
that is C code:
that is C code:
#include <t89c51Rx2.h> // unsigned char rcvd[2]; unsigned char j; unsigned char k; bit ok=0; bit ok1=0; void init() /// u put int() here { TMOD=0x20; TH1=0xFD; SCON=0x50; TR1=1; } void sendString(unsigned char *a) { while(*a!='\0') { SBUF=*a; while(TI==0); TI=0; a++; } } void sendChar(unsigned char b) { SBUF=b; while(TI==0); TI=0; } unsigned char rcv() { while(RI==0); RI=0; return SBUF; } void checkOK() { for(j=0;j<2;j++) rcvd[j]=rcv(); if(rcvd[0]=='o'&&rcvd[1]=='k') ok=1; else ok=0; } void checkOKe() { k=rcv(); if(k=='> ') ok1=1; else ok1=0; } void main() { P2_0=0; P2_1=0; while(1) { if(P1_0==0) { init(); sendString("AT"); sendChar(0x0D); checkOK(); if(ok==1) { P2_0=1; sendString("AT+CMGS=19"); sendChar(0x0D); checkOKe(); if(ok1==1) { P2_1=1; sendString("079109459208003311000C910945664173350000AA05E8329BFD06"); //sms center no:+905429800033, destination number:+905466143753, message:"HELLO" sendChar(0x1A); } else P2_1=0; } else P2_0=0; } } }
[ Edited Wed Apr 23 2008, 02:18 pm ]
Wed Apr 23 2008, 08:55 am
what is this??
PDU??
doesnot the modem support text mesaging???
Wed Apr 23 2008, 09:40 am
yes it is pdu mode.Because my cellphone is siemens C55 and it supports only pdu mode.
I can send sms by hyperterminal with pdu mode.And I simulated it by proteus.Serial communication looks success.But it doesnt work when I do that schematic.Cellphone close itself.I dont know why?
Wed Apr 23 2008, 02:23 pm
problem seems here..
you are checking for small 'o' and small 'k' whereas phone sends capital 'O' and capital 'K'. so you variable ok is never 1. I hope you got my point.
So make the change in program as..
if(rcvd[0]=='O'&&rcvd[1]=='K')
cllunlu like this.
Wed Apr 23 2008, 02:43 pm
also you dont need to send all those commands...just try to send at+cmgs.and dont check OK.
Wed Apr 23 2008, 02:49 pm
I know.But I wanna check my pdu mode.So I have to know right communication.And my schematic is right?
Wed Apr 23 2008, 03:09 pm
But I dont understand DTR pin of mobile=high
how it will be.It necessary.And how?
Wed Apr 23 2008, 03:13 pm
do you know pin configuration of your mobile connector??you are not using datacable right?
