Discussion in "Project Doubts" started by    junied    Aug 8, 2006.
Tue Aug 08 2006, 07:38 pm
hi !
ajay i had just tried to run the code in keil and got A6 error
please have a look at this code and try to compile it in keil
build: mov a,#40h ;Building custom character routine
acall command
build_char 04h,eh,eh,eh,1fh,0h,4h,0h ;BELL
build_char 1h,3h,0fh,0fh,0fh,3h,1h,0h ;SPEAKER OFF
build_char 8h,10h,0h,18h,0h,10h,8h,0h ;SPEAKER ON
build_char 0h,0eh,15h,17h,11h,0eh,0h,0h ;CLOCK
build_char 0h,1h,3h,16h,1ch,8h,0h,0h ;OK
build_char 0ah,1fh,1fh,1fh,0eh,4h,0h,0h ;HEART
build_char 2h,3h,2h,0eh,1eh,0ch,0h,0h ;MUSIC
ret
and i have initialized
build_char macro P1,P2,P3,P4,P5,P6,P7,P8 irp arg, mov a,#arg acall data_in endm endm
; build_char macro P1,P2,P3,P4,P5,P6,P7,P8*/ ;Macro for building a custom charac
; irp arg, <P1,P2,P3,P4,P5,P6,P7,P8>
mov a,#arg
acall data_in
endm
endm
this code at beginning
so please reply!!!
Tue Aug 08 2006, 08:06 pm
its working.. what the problem in it? i mean.. you have to define each and eveything which is being used inside
i.e. the subroutine command, data_in
the code you have posted will not work alone
 irp arg,
  mov a,#arg
  acall data_in
 endm
endmbuild: mov a,#40h ;Building custom character routine
acall command
ret
[ Edited Tue Aug 08 2006, 08:08 pm ]
Tue Aug 08 2006, 08:33 pm
look at these errors in keil!! u may understand the problem from these errors
[ Edited Wed Aug 09 2006, 12:19 am ]
Wed Aug 09 2006, 12:23 am
first of all... please remove the startup.A51 file coz we are not using it in this case.. we use it mostly when we are dealing with C and assembly both
and if you are using it. send me the updated code
tell me which version of C51 you are using...
Wed Aug 09 2006, 02:13 am
i have removed the startup file although it dosent make any difference untill u add it in ur code.u wanted the information about my keil version so i am sending it to u
[ Edited Wed Aug 09 2006, 11:50 am ]
Wed Aug 09 2006, 03:59 am
thats good
Wed Aug 09 2006, 04:02 am
and you have removed the license part check your hotmail mailbox
Wed Aug 09 2006, 11:10 am
There is no problem with keil. it is working.
Wed Aug 09 2006, 11:22 am
it is working fine. it is also a full project. :hug
[ Edited Wed Aug 09 2006, 11:54 am ]
Wed Aug 09 2006, 11:37 am
:rose
[ Edited Sun Aug 13 2006, 10:58 pm ]
