serial pinouts
Mon Mar 24 2008, 07:01 pm
yup all is working fine. i hve configured it with pc. and also checked the micro's serial port..... now it only seems to me that the fault culd be in programming
Mon Mar 24 2008, 10:44 pm
have you tested micro with your program on hyper terminal??? if u getting the desired result then programming wil be ok.......... one thing important
i heard from a frend of mine that
"t630 is not autobaud rate compatible".he tried the same as you are trying ..but he got no success :-|
Guy like this.
Sun Mar 30 2008, 10:16 pm
now i hve done all that and the mobile is dialing too according to the at command
now another prob is that how to check the response which the mobile gives to at command
eg
for AT the mobile gives OK
how to check whether the cell phone is giving response or not......
I ve connected the txd of cell phone to rxd of controller
eg
Mon Mar 31 2008, 12:46 am
for this testing.. you first need to connect your cell phone to Computer's COM port and open hyperterminal for checking AT Command response.
Mon Mar 31 2008, 09:55 pm
so are you getting any response on hyperterminal when you send AT to mobile?
Thu Apr 03 2008, 09:15 pm
which command shud i use to automatically display the new sms in text mode on hyperterminal.... i know at+cnmi=2,3,2,0,0 to receive sms and display in pdu format.....
