Discussion in "Project Help" started by    Ansh12    Mar 22, 2019.
Sun Apr 28 2019, 02:15 PM
I made a minor change, it works in Proteus.
Try the attached hex code, just in case you have a compiler problem.
Are you sure you are getting a good signal into pin RB0 ?
if(INTF==1)
         RD4 = 1;  // LED ON
         __delay_ms(1000); //
         RD4 = 0;  // LED OFF
         INTF = 0;
you are absolutely right. I reinstalled MPLABX IDE and my previous program is working now
Now all is working so I want to do little changes
I have one sensor when it triggered I want to start counting. How to do it ?
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
#define _XTAL_FREQ 20000000 //Specify the XTAL crystal FREQ
#include
volatile unsigned int Counter;
char Trigger;
void main(void)
    TRISB0=1;     // encoder as input
    TRISB1=1;     // Sensor as input
    TRISD1= 0;    // LED as output
    OPTION_REG=1;  // Set Rising Edge Trigger
    INTCON = 1;   // Enable The Global Interrupt
    INTE = 1;     // External Interrupt Enable (not INTF)
    GIE=1;
    Counter = 0;  //initial values at start up
    Trigger = 0;
    while (1)
        if(Trigger == 1)
             Trigger = 0;
             Counter = 0;
             RD1 = 1;  // LED ON
             RD1 = 0;  // LED OFF
             __delay_ms(500);
void interrupt isr(void)
    if(INTF==1)
        INTF = 0;  // Clear interrupt flag
        Counter++;    // add 1 to the Counter
        if(Counter == 30)
        Trigger = 1;
[ Edited Sun Apr 28 2019, 02:17 PM ]
Fri Apr 16 2021, 08:49 AM
Maria Campbell
It looks like you've misspelled the word "temprature" on your website. I thought you would like to know . Silly mistakes can ruin your site's credibility. I've used a tool called SpellScan.com in the past to keep mistakes off of my website.-Maria
Thu Apr 15 2021, 11:47 PM
Rachel Cohen
Wed Apr 14 2021, 07:42 PM
Harmanjsj
only
Wed Apr 14 2021, 05:05 PM
Valencia
Thank you for some other excellent article. Where else may anyone get that type of info in such a perfect manner of writing? I have a presentation subsequent week, and I'm on the search for such info. viagra otc https://viagrasildenafilok.com/
Wed Apr 14 2021, 03:56 PM
Maritza
Hello, i think that i noticed you visited my web site thus i came to return the prefer?.I am attempting to in finding issues to improve my website!I assume its good enough to make use of a few of your ideas!! https://auto.rifugiofiori.it/docbook-sample.pdf Katja
Guests: 122, Members: 0 ...
