GSM based notice board
Discussion in "Project Doubts" started by Sudhansudeep Aug 31, 2018.
Fri Aug 31 2018, 06:09 PM
Shall I use the program as it is given with out any changes? And Can I use the same program for 16x4 LCD sir?
Fri Aug 31 2018, 08:41 PM
Status messages over 16 chars will need to be trimmed to 16 chars.
You will need to modify the LCD display routine to start a new line
after every 16 chars.
You will have to change 'Mob_no' to match your mobile.
unsigned char code Mob_no[]= "9739317976";
http://www.8051projects.net/download.php?view.248
[ Edited Sat Sep 01 2018, 01:25 AM ]
Sat Sep 01 2018, 05:58 AM
Thank you sir I have understood that I have to change the mobile number and have to give my mobile number which I will be using. But I did not understand the concept that u have stated regarding the LCD display to trimm to 16 chars will u please tell me which line of the program to change it to 16 chars
Sun Sep 02 2018, 09:46 PM
Okay.. I assumed the project would use all 4 lines.
In fact it only uses 2, so I wonder why a 4 line display is used.
The project will only safely display message up to 10 bytes long,
which is odd, but means no changes are needed for a 16 * 4 or 16* 2 display.
Simple changes allows 16 /20 char messages.
Add
#define LCDWIDTH 16 //or 20
unsigned char store[LCDWIDTH+1];
change store_msg()
Also change clear_mybuff() as buffer is declared as 20 bytes
Add
change store_msg()
void store_msg(unsigned char msg_array[]) { unsigned char i,j; i=59; j=0; while(msg_array[i]!='\r') // copy to end of line or buffer full { store[j]= msg_array[i]; i++; j++; if( j > =LCDWIDTH) break; //stop at 16 / 20 } store[j]= 0; //terminate the string return; }
void clear_mybuff() { unsigned int a; for(a=0;a<20;a++) MyBuff[a]=0x00; }
[ Edited Sun Sep 02 2018, 09:52 PM ]
Mon Sep 03 2018, 03:02 AM
change store_msg()
Shall I need to write the above lines also??
change store_msg()
Mon Sep 03 2018, 08:47 PM
This version supports 16 character messages on 16*4 or 16*2 LCDs
[ Edited Mon Sep 03 2018, 08:55 PM ]
Tue Sep 04 2018, 03:01 PM
sir i have compiled the above program i am getting the following error
LENGTH:006H
ERROR L105: PUBLIC REFERS TO IGNORED SEGMENT
SYMBOL: MSG1
SEGMENT:?ID?GSMKEIL3
program size: data=176.5 xdata=0 code=1909
target not created
LENGTH:006H
SYMBOL: MSG1
target not created
Tue Sep 04 2018, 04:16 PM
please sir can u help me in removing this error as i am using a kiel uvision 3 software as i have to complete my project in few days
Tue Sep 04 2018, 06:49 PM
Have you made any changes to the code I posted ?
The errors might be due to the version of Keil you are using.
The best fix is to get the evaluation version of Keil 5.
It has a limit of 2K, but this project is less than 2K so will be okay.
You have to register but it is free.
https://www.keil.com/demo/eval/c51.htm
Does the original project compile ?
If so you could just use that and edit your phone number and
status messages to fit.
[ Edited Tue Sep 04 2018, 07:56 PM ]
