ac motor controller using 8051
Mon Jul 02 2018, 08:22 AM
hi sir
as u mentioned in the program i have checked the pin output on pin 12,17,and 39 the waves is all the same and sir i have applied capaictors on output of 7805 as well
link below
https://drive.google.com/file/d/1DgynvYdqbpuDR1c0lYrfjwpV37LLKOs6/view?usp=drivesdk
now what changes should i do ??? to control mine motor perfectly
and sir i have connected transformer its giving perfect 100hz on pin 12
the output voltage of transformer is 12.10 v
i dont have perfect 9v transformer is it ok to work on 12.10 v
link below
Mon Jul 02 2018, 06:20 PM
Yes, that is ok.
Try the original code again.
You can not control that kind of motor.
Use a light bulb.
Yes, that is ok.
Use a light bulb.
Fri Jul 06 2018, 01:33 PM
hi sir
as u told
i have tried using mixer motor link below
https://drive.google.com/file/d/1J8khUV37XSPSMA0ylFEOAhb7sW8B-SaV/view?usp=drivesdk
and i have tried using 200 watt bulb as well link below
https://drive.google.com/file/d/1fU5_SDEB-EaofEYV45zcjsLls_iQsaZC/view?usp=drivesdk
sir what should i do ??
can change in the program can control the bulb if yes ?? then what changes should i do
as u told
Fri Jul 06 2018, 11:58 PM
Okay..
That motor creates a lot of sparks which might confuse any micro,
It also looks dangerous
Better to use a light bulb. 50- 100 watts should be okay.
Here is a test program.
It uses no timers, buttons or interrupts, so is as simple as possible.
It does still need the input on pin 12.
It should light the bulb in 4 second steps from low to high power,
lighting the led display as it goes , then repeat.
If it does not work ,can you use the scope on the output (pin 39)
and make a video.
and make a video.
Mon Jul 09 2018, 08:14 AM
hi sir
as u mentioned above program i have tried
yellow pin 12 and blue pin 39 link below
https://drive.google.com/file/d/11CFf408hAB90kKPZH4eDKBrbNagpc3ca/view?usp=drivesdk
but sir there is no effect on bulb here i haved used 60 watt bulb but sir its showing waves on pin 39 on oscillscope as it increases as mentioned in video
Mon Jul 09 2018, 06:55 PM
Okay that is very interesting.
I have attached two screenshots.
One shows my Proteus simulation of what the display should look like.
You see one blue pulse (pin 39) for each yellow pulse (pin 12).
On your oscilloscope display, there is one pin 39 for every 3 pulses on pin 12.
We need to find out way.
It looks as if your clock speed is wrong.
What crystal are you using ?
Which micro are you using ?
The pulses on pin 39 should be 1 millisecond wide,what are they ?
There is still a lot of noise on pin 39, I have circled this in red.
So much noise will cause problems.
Please check the 5 volt supply with your oscilloscope to see if it
is noisy.
Do you have Proteus ?
is noisy.
Tue Jul 10 2018, 06:06 AM
hi sir
i have checked now much of the distortion in waves on pin 39 is being removed and bulb is also working fine
but sir i have to control it manually by switches can u send me asm file
motor_speed_control.zip
link below
https://drive.google.com/file/d/13DOt52YGQagnIuBtz71V5T7P5Nwvv4Yu/view?usp=drivesdk
IC:-AT86S52
CRYSTAL:-12MHz
yes i have proteus
and sir i have to desing this for fan what should i do???
link below
IC:-AT86S52
CRYSTAL:-12MHz
yes i have proteus
Tue Jul 10 2018, 07:20 PM
I assume you meant a AT89S52.
It seems to me that the micro is running at the wrong speed (about 6 MHz)
Check the crystal with your scope.
The pulses on pin 39 should be 1 millisecond wide, how wide are they ?
I would replace the crystal and its capacitors.
I don't think this controller will make a good speed controller for a fan.
In any case we can't work on that until we have it working.
[ Edited Tue Jul 10 2018, 09:44 PM ]
Thu Jul 12 2018, 06:51 AM
hi sir
as u mentioned above to change crystal and capacitors finally its working fine
and i have burnerd the original program its also working as well
link below
https://drive.google.com/file/d/1-lXDVgWiRw6H0u9Vntb5nAR2RxORBFbP/view?usp=drivesdk
sir i have some query about mine project( ac motor controller)
we can control our ac motor through regulator so whats difference between this project and regulator and advantages ????
link below
Thu Jul 12 2018, 08:27 PM
I'm glad we got there in the end
Really this project is the same kind of regulator.
One difference is that you made it yourself.. more or less
With a normal regulator you have to be there to turn the dial,
with this project you can control motors or lights remotely
or by computer
or by computer
