ac motor controller using 8051
Thu Apr 12 2018, 06:51 PM
hii sir,
I am working on ac motor controller .I have connected circuit as per given circuit diagram but sir instead of this
sbit led1 = p3^7;
sbit led2 = p3^6;
rest all led are glowing
and sir i don't get output on optocoupler as well
and sir innstead of 9v transformer I have used 9 volt battery as input.
plz help me out
is something wrong with program code..
sbit led1 = p3^7;
sbit led2 = p3^6;
plz help me out
Fri Apr 13 2018, 02:09 AM
I assume you are doing this project.
http://www.8051projects.net/download-d238-single-phase-ac-motor-speed-controller-project-report.html
In that case it will not work if you replace the 9v transformer with a battery.
The transformer provides a timing signal.
The LEDs should still change when you press the buttons.
Have you got a serial connection to your PC ?
Mon Apr 16 2018, 06:39 AM
Mon Apr 16 2018, 08:49 PM
On the diagram, a diode feeds a rectified sine wave to R1.
The circuit feeds a signal to P3.2 (INT 0) at the low point.
This pulse is needed to time the output on P0.0
Using a battery you will not get an output on P0.0
but you should still see the LEDs on port 2 change
as you press buttons SW2 and SW3
>Sir isn't any problem if i control my speed of motor
>by means of switch sw2 and sw3 ??
No problem, I ask because a serial link can be useful for testing.
It is easy to add with a USB/Serial adapter.
The 240 volt circuit seems close to the low voltage side.
240 volts can kill.
Move the 240 volt circuit and MOC3011 to a separate board.
240 volts can kill.
[ Edited Mon Apr 16 2018, 10:25 PM ]
Fri Apr 27 2018, 05:33 PM
Hi sir
I have connected circuit as per given circuit diagram every thing is working fine and mine optocoupler is showing ouptut as well but sir mine fan is not showing any response even though i am pressing increment and decrement switch and i am using exhaust fan and in snubber circuit i have kept R value as 390 ohm and C value is 103/1kw and sir i have also connected 200 watt bulb in place of exhaust fan but its same it also not showing any response
Fri Apr 27 2018, 08:03 PM
Using a light bulb is a good idea.
Disconnect the mains side of things while testing.
Fit an LED in place of the control side of the MOC3011.
That is.
Disconnect the MOC3011 and put an LED between the 220ohm
resistor and the 8051 pin 39. (port 0.0)
It should turn on and off and vary in response to to buttons.
Do the indicator LEDs change as expected ?
That is.
[ Edited Fri Apr 27 2018, 08:08 PM ]
Sat Apr 28 2018, 08:00 AM
Hi sir
as u told i have connected led between 220 ohm resistor and pin 39 and the led turn on and off and vary in response to buttons as expected
Sat Apr 28 2018, 08:33 PM
If the LED is turning on and off and varying, then the fault is
on the mains side.
Does the light turn on and off when connected to the micro ?
If it is always on, you have a faulty triac, or your wiring
is wrong.
on the mains side.
is wrong.
Mon Apr 30 2018, 10:33 AM
Mon Apr 30 2018, 06:48 PM
You say you used a MOC2021, I can't find a data sheet , is it a MOC2021 ?
Okay.. so current is flowing to the motor ,we need to find out how.
First change the motor to a light bulb, say 100Watts. it will give a better idea of how
much current is flowing.
Is it full brightness ?
Next remove the opto-isolator.
Any change ?
Remove 360 ohm resistor and 0.05Uf cap
Any change ?
Remove BT136.
Report back.
Any change ?
Any change ?
Remove BT136.
Report back.
