Discussion in "8051 Discussion Forum" started by    Ansh12    Feb 25, 2018.
Sun Feb 25 2018, 10:06 pm
I want to see character back to terminal whatever I type on terminal. My code is not working
#include <reg51.h>
void uart_init();
char getc();
void putc (char c);
void puts(char *s);
void uart_init()                  // Initializes UART peripheral
  TMOD = 0x20;                    // Timer1, mode 2
  TH1  = 0xFD;                    // 9600 bps 11059200 Clock, core(12cycle), uart(SMOD=0)
  TL1  = 0xFD;                    // First byte timing
  SCON = 0x52;                    // 0x52 : 0101 0010  Receive Enable, TI as 1 (set as ready)
  TR1  = 1;
char getc()                       // Polled method to Receive a byte(8bit)
  while (RI == 0);                // Wait until a byte has been received
  RI = 0;                         // Acknowledge RI
  return SBUF;
void putc (char c)
  while (TI == 0);
  SBUF = c;
void puts(char *s)           // Typical puts for uart Transmit a string-null-terminated
  while (*s!=0)                   // Check for null byte termination
  putc(*s++);                // and send each byte using uart
void main ()
   char c;
   uart_init();             // Init UART to desired settings
   puts("Anssh");
   while (1)
	{                         // This loop echoes back whatever is typed on PC Keyboard
     c = getc();            //    get next byte from PC
     putc(c);               //    and send it back as echo
How to get echo character on terminal?
Mon Feb 26 2018, 04:21 am
You need to reset TI
void putc (char c)
  while (TI == 0);
  TI = 0;
  SBUF = c;
 Ansh12 like this.
Mon Feb 26 2018, 06:58 am
Can you give a little more information about this. How to do it ?
Wed Feb 28 2018, 04:22 am
Use the code in my last post.
Wed Feb 28 2018, 04:58 am
I did but code is not working
#include <reg51.h>
void uart_init();
char getc();
void putc (char c);
void puts(char *s);
  TR1  = 1;
  return SBUF;
void putc (char c)
  while (TI == 0);
  TI = 0;
  SBUF = c;
void main ()
   char c;
   puts("Anssh");
   while (1)
Wed Feb 28 2018, 05:45 am
I tested the code you posted in Proteus and it works.
Be sure Proteus is loading the correct code.
If it still does not work, post your Proteus and Keil files.
Wed Feb 28 2018, 06:11 am
Please look at the attached file
Wed Feb 28 2018, 07:18 am
In the rar file you just posted,
the routine "void putc (char c) "
does not contain the line "TI=0;"
Add it.
Wed Feb 28 2018, 09:02 am
Add it.
sorry for posting wrong file but still I am not getting echo character
look at this file
Thu Mar 01 2018, 03:42 am
TI= 0 is still missing
from putc (char c)
utaletxcyw
Wed Apr 17 2024, 10:21 am
Anthonyvab
Wed Apr 17 2024, 08:48 am
RobertCix
Wed Apr 17 2024, 06:46 am
