Automatic Room light Controller with Visitor Counter (AT89S52)
Thu Jan 03 2013, 03:33 pm
thanks majoka but im still confused how to connect 7 segment display with ic AT89s52..can you show how to connect it?
Sun Jan 13 2013, 07:15 pm
@ sk8ter_jawe
simply connect a,b,c,d,e,f,g segments to each other and then finally with microcontroller
then you need of multiplexing
send 1st segment data on controller port and switch on the 1st transistor
now send 2nd segment data on controller port and switch on the 2nd transistor and so on
at a time one transistor should on
http://www.8051projects.net/t37289/8051-discussion-forum/source-code-circuit-diagram-for-8-seven-segment-fully-working.htm
Wed Jul 17 2013, 04:38 pm
I have a doubts in the coding.
1.the line means that "JNB SEN2,$",if sen2 is 0,then it keeps on waiting until it becomes 1.am I right?
2. the visitor count will be in the label "visitor" or "count".is count the number of digits?
3.In the coding port 2.7 is labeled as light.if I want to add another light which glows when visitor count goes certain limit,can I add it at another port as "light1 equ p2.8" and where should I add the condition like "if(visitor==50) setb light1" in the code?
can anyone help me.
4.why value_1 and value_2 are first assigned 15h and then 00h ?
5.please can anyone explain the logic of interrupt program alone?
can anyone help me.
[ Edited Wed Jul 17 2013, 09:37 pm ]
Fri Jul 19 2013, 12:09 am
gsriram187
Yes right..
gsriram187
Visitor count will be stored in VISITOR and COUNT is used to switch between 7-seg display.
gsriram187
yes you can add one more the same way Port 2.7 is used. but there is no P2.8 in 8051 you can use any other free port pin though.
search for following area where LIGHT is turned on
UP_COUNT: SETB LIGHT INC VISITOR
here after visitor is incremented you can compare visitor value and see if its greater than 50 and accordingly turn on your second light.. but you have to take care the same thing for turning off of lights.
gsriram187 like this.
Fri Jul 19 2013, 10:01 pm
thanks for the reply.sorry for that port "2.8".i will try changing that code.
Sat Jul 20 2013, 10:21 pm
hi.i don't have the ride compiler.i am not able to download it too.can anyone convert this file into hex file and give me.i have just changed the port number assignments of the display as of now..
[ Edited Sun Jul 21 2013, 09:22 am ]
Sat Jul 20 2013, 10:24 pm
also I can't understand why value_1 and value_2 are initialized to a value 15h and then changed to 00h
Wed Jul 24 2013, 07:29 pm
please anyone reply.can someone give me the link to download ride software (evaluation or free version).because I should program the controller soon.
Wed Jul 24 2013, 08:30 pm
This code does look much different to Keil assembly code.
Have you tried to convert it to Keil ?
edit
Should be
This code does not look much different to Keil assembly code.
edit
Should be
[ Edited Thu Jul 25 2013, 08:08 pm ]
