Discussion in "Project Doubts" started by    sankalp_s    Nov 30, 2014.
Thu Feb 18 2016, 12:09 am
#81
It is just a case adding loops to the code,
I'm sure you will work it out.
Thank you so much sir, for great help and great support.
sure sir i'll try for that.
Sat Jan 14 2017, 12:22 am
#82
Hi phill sir..
testButton1:
				 mov A,BIT_VAR ;debug
				 mov P1,A
		        jb progBit1,testButton2
				orl P1,#0x20  ;debug
                call program0  ;Run this segment if button pressed
                sjmp testButton1  ;done
testButton2:
				jb progBit2,default
				orl P1,#0x40  ;debug
                call program2  ;Run this segment if button pressed
                sjmp testButton1
default:
                orl P1,#0x80  ;debug
                call program1  ;Run this segment if no buttons pressed
                sjmp testButton1
Above mention code is not working.. only default program executes..whatever conditions of buttons, they are pressed or not it makes no any changes.(This function works fine with old code but not working with this table method)
And sir please also explain me how can add 24 bit display.. i'm unable to increase from 16 to 24 bcoz of DPTR limitations.
Thanks sir.
I've attached the whole code..
[ Edited Mon Jan 16 2017, 01:30 am ]
Sun Jan 15 2017, 05:24 am
#83
There is a fault in your Proteus design.
If you look carefully (magnify) you will see the ground point is actually a junction dot.
Add a new ground point from the 'Terminal mode ' menu.
The buttons will work now.
Buttons should show as red and blue, and change when pressed,
If not, post your Proteus design and the code you are using.
Mon Jan 16 2017, 01:25 am
#84
Hello sir, i'm using the code in development board where every thing is ok..
i'm attaching both non working and working code here.
please look both once. There is no changes in asm files of both codes but include files are different.. in non working code *.inc file is written in table method and other which is working, written in old method which is DUMPED by us.
i've tried both.
[ Edited Mon Jan 16 2017, 01:29 am ]
Wed Jan 18 2017, 06:26 am
#85
Here is a new version that works on the circuit you posted.
"And sir please also explain me how can add 24 bit display..
The DPTR does not impose any limitation on the number of LEDs.
If you look at "displayloop:" you will see that it moves one byte at a time from the table
to a port.
Just move three bytes (24 bits) instead of 2 (16 bits) in every call to "displayloop:"
 sankalp_s like this.
Thu Jan 19 2017, 12:58 am
#86
Thank you so much dear sir. I think problem was memory allocation..
to a port.
I'm doing like dis:
dw 000000000000000000000000b
       dw 100000000000000000000000b
       dw 110000000000000000000000b
	   dw 111000000000000000000000b
	   dw 111100000000000000000000b
	   dw 111110000000000000000000b
	   dw 111111000000000000000000b
displayloop:
     mov A,table_count  ;copy the number of lines to display
     mov tmp_table_count,A
d_loop:
     mov A,#0
     movc A,@A+dptr ;get the top 6 bits
	call mirrorbyte; ;reverse pattern to suit hardware
	 mov P1,A      ;display pattern
	 inc dptr
	 mov A,#0
     movc A,@A+dptr ;get the low 6 bits
	 call mirrorbyte
	 mov P0,A
	 inc dptr
	  mov A,#0
	 call mirrorbyte
	 mov P2,A
	 inc dptr
	 //call delay2       ;pause
	 call delay_keycheck    ;pause and checkbuttons.. can change return address, be careful
	 djnz tmp_table_count,d_loop	;next line of table
     ret
It gives result like zig zag and blinking (not according to given instructions.) m i doing wrong sir?
Thu Jan 19 2017, 02:58 am
#87
This is your error
"dw 000000000000000000000000b"
dw stands for define word, meaning 16 bits of storage.
The assembler only stored 16 bits of the 24 bits you expected.
In the attached file I use.
dw 0000000000000000b
db 00000001b
This stores 16 bits then 8 bits per entry.
Don't forget, I used P1 for debugging, you will need to turn that off.
Thu Jan 19 2017, 11:22 pm
#88
Thank you sir.. understood the logic..
But reverse loop is not working for 24 bits only port 2 and port 2 are functioning.
I'm doing this:
	reverse24displayloop:
	 rl A ;2 bytes per line
inc_dptr24:
	 dec A
	 jz noinc_dptr
	 inc dptr
	 jmp inc_dptr24
noinc_dptr24:
r_loop24:
     mov A,#0
	 mov P2,A      ;display pattern
	 ;8051 has no "dec dptr" instruction, so do it the hard way.
	 dec DPL
	 MOV R7,DPL
	 cjne R7,#255,rdl1_24
	 dec dph
rdl1_24:
	 mov A,#0
	 call mirrorbyte
	 mov P0,A
	 dec DPL
	 MOV R7,DPL
	 cjne R7,#255,rdl2_24
	 dec dph
 rdl2_24:
	 mov A,#0
	 call mirrorbyte
	 mov P0,A
	 dec DPL
	 MOV R7,DPL
	 cjne R7,#255,rdl3_24
	 dec dph
rdl3_24:
	 djnz tmp_table_count,r_loop
     ret
Fri Jan 20 2017, 06:01 am
#89
The original reverse24displayloop:
was a bit messy.
Try this version.
[ Edited Sat Jan 21 2017, 03:14 am ]
 sankalp_sajay_bhargav like this.
Fri Jan 20 2017, 10:10 pm
#90
Thank you so much sir for your great response..
HenryLaf
Mon Apr 22 2024, 03:50 pm
bleradrar
Mon Apr 22 2024, 06:38 am
ppu-pro_ka
Sun Apr 21 2024, 07:39 pm
Infewow
Sun Apr 21 2024, 06:30 pm
