Discussion in "Project Doubts" started by    sankalp_s    Nov 30, 2014.
Thu Dec 18 2014, 09:54 am
Code is all ok.. just change EXT0 to EX0... By mistake I wrote the wrong bit name. EX0 is for external interrupt 0.
 sankalp_s like this.
Fri Dec 19 2014, 02:02 am
SIR THIS CODE IS NOT WORKING..
ORG 000H ; starting address
SJMP LABEL
ORG 13H
    JNB P3.3, $
    RETI
SJMP LABEL1
LABEL1:
SETB EX1 ; Enable external interrupt 1
SETB EA   ; Enable interrupts
L1 EQU	 P1.2 ;LED CONECTED TO THIS PORT
L2 EQU	 P1.3 ;LED CONECTED TO THIS PORT
L3 EQU   P1.4 ;LED CONECTED TO THIS PORT
L4 EQU   P1.5 ;LED CONECTED TO THIS PORT
L5 EQU   P1.6 ;LED CONECTED TO THIS PORT
L6 EQU   P1.7 ;LED CONECTED TO THIS PORT
LABEL:
MOV R3, #05 ;REPEtion of pattern
D7:	CALL DESGN7
DJNZ R3,D7
D8:	CALL DESGN8
DJNZ R3,D8
D9:	CALL DESGN9
DJNZ R3,D9
JMP LABEL
DESGN7:	CALL ALLON
CALL DELAY
SETB L1
CALL DELAY
SETB L2
CALL DELAY
SETB L3
CALL DELAY
SETB L4
CALL DELAY
SETB L5
CALL DELAY
SETB L6
CALL DELAY
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
DESGN8:	CALL ALLON
SETB L6
SETB L1
CALL DELAY
CALL ALLON
SETB L5
SETB L2
CALL DELAY
CALL ALLON
SETB L4
SETB L3
CALL DELAY
RET
DESGN9:	CALL ALLON
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
CLEAR:	SETB L1
SETB L2
SETB L3
SETB L4
SETB L5
SETB L6
RET
ALLON:	CLR L1
CLR L2
CLR L3
CLR L4
CLR L5
CLR L6
RET
DELAY:	MOV R0,#0FFH
INLOP:	MOV R1,#0FFH
DJNZ R1,$
DJNZ R0,INLOP
RET
END
Fri Dec 19 2014, 02:06 am
i've tried this code but faced a syntax error on line of setb ext0...
( Symbol not defined: ext0)
sankalp_s
Which compilier are you using ?
sir one thing more can u give me the while loop code
example for my requirement ..
sankalp_s
ORG 03H
JNB P3.2, $
RETI
This is all the code you need to freeze the display.
can i use pin int1 for this operation?
sankalp_s
Yes, but the code changes to..
    ORG 13H
    JNB P3.3, $
    RETI
//and
SETB EXT1 ; Enable external interrupt 1
An alternative method does not use an interrupt.
Monitor the key in the delay routine.
DELAY: MOV R0,#0FFH
INLOP: MOV R1,#0FFH
buttonTest:             ;button is the input pin
JNB button, buttonTest  ;wait while pressed
DJNZ R1,buttonTest
DJNZ R0,INLOP
RET
I'm using mcu8051ide for compiling..
and sorry sir the alternate code is also not working..
Fri Dec 19 2014, 02:10 am
SJMP LABEL
ORG 13H
    JNB P3.3, $
    RETI
SJMP LABEL1
LABEL1:
LABEL:
D7:	CALL DESGN7
DJNZ R3,D7
D8:	CALL DESGN8
DJNZ R3,D8
D9:	CALL DESGN9
DJNZ R3,D9
JMP LABEL
DESGN7:	CALL ALLON
CALL DELAY
SETB L1
CALL DELAY
SETB L2
CALL DELAY
SETB L3
CALL DELAY
SETB L4
CALL DELAY
SETB L5
CALL DELAY
SETB L6
CALL DELAY
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
DESGN8:	CALL ALLON
SETB L6
SETB L1
CALL DELAY
CALL ALLON
SETB L5
SETB L2
CALL DELAY
CALL ALLON
SETB L4
SETB L3
CALL DELAY
RET
DESGN9:	CALL ALLON
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
CLEAR:	SETB L1
SETB L2
SETB L3
SETB L4
SETB L5
SETB L6
RET
ALLON:	CLR L1
CLR L2
CLR L3
CLR L4
CLR L5
CLR L6
RET
DELAY:	MOV R0,#0FFH
INLOP:	MOV R1,#0FFH
DJNZ R1,$
DJNZ R0,INLOP
RET
END
sankalp_s
sir can you explain what is missing in this code?
what would value of R3 in this code.
Fri Dec 19 2014, 05:51 am
This version works.
Edit it to use either method.
SJMP LABEL
ORG 13H
    JNB P3.3, $
    RETI
LABEL:
;SETB EX1 ; Enable external interrupt 1
;SETB EA   ; Enable interrupts
D7:	CALL DESGN7
DJNZ R3,D7
D8:	CALL DESGN8
DJNZ R3,D8
D9:	CALL DESGN9
DJNZ R3,D9
JMP LABEL
DESGN7:	CALL ALLON
CALL DELAY
SETB L1
CALL DELAY
SETB L2
CALL DELAY
SETB L3
CALL DELAY
SETB L4
CALL DELAY
SETB L5
CALL DELAY
SETB L6
CALL DELAY
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
DESGN8:	CALL ALLON
SETB L6
SETB L1
CALL DELAY
CALL ALLON
SETB L5
SETB L2
CALL DELAY
CALL ALLON
SETB L4
SETB L3
CALL DELAY
RET
DESGN9:	CALL ALLON
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
CLEAR:	SETB L1
SETB L2
SETB L3
SETB L4
SETB L5
SETB L6
RET
ALLON:	CLR L1
CLR L2
CLR L3
CLR L4
CLR L5
CLR L6
RET
DELAY:	MOV R0,#0FFH
INLOP:	MOV R1,#0FFH
buttonTest:
;JNB P3.3, buttonTest  ;enable this line wait while pressed
DJNZ R1,buttonTest
DJNZ R0,INLOP
RET
END
[ Edited Fri Dec 19 2014, 06:10 am ]
Fri Dec 19 2014, 11:34 pm
This version works.
SJMP LABEL
ORG 13H
    JNB P3.3, $
    RETI
LABEL:
D7:	CALL DESGN7
DJNZ R3,D7
D8:	CALL DESGN8
DJNZ R3,D8
D9:	CALL DESGN9
DJNZ R3,D9
JMP LABEL
DESGN7:	CALL ALLON
CALL DELAY
SETB L1
CALL DELAY
SETB L2
CALL DELAY
SETB L3
CALL DELAY
SETB L4
CALL DELAY
SETB L5
CALL DELAY
SETB L6
CALL DELAY
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
DESGN8:	CALL ALLON
SETB L6
SETB L1
CALL DELAY
CALL ALLON
SETB L5
SETB L2
CALL DELAY
CALL ALLON
SETB L4
SETB L3
CALL DELAY
RET
DESGN9:	CALL ALLON
CALL DELAY
SETB L6
CALL DELAY
SETB L5
CALL DELAY
SETB L4
CALL DELAY
SETB L3
CALL DELAY
SETB L2
CALL DELAY
SETB L1
CALL DELAY
RET
CLEAR:	SETB L1
SETB L2
SETB L3
SETB L4
SETB L5
SETB L6
RET
ALLON:	CLR L1
CLR L2
CLR L3
CLR L4
CLR L5
CLR L6
RET
DELAY:	MOV R0,#0FFH
INLOP:	MOV R1,#0FFH
buttonTest:
DJNZ R1,buttonTest
DJNZ R0,INLOP
RET
END
Thank u so much sir for your quick response..
sir code which is posted last time by u is working.. but when interrupt occurs then main function do not work.. only led blow continuously.. but i want something else
I'm very sorry sir it was my mistake that i could no explain exact need.
ok i explain what i want to do.
please look this code
D7:	CALL DESGN7
DJNZ R3,D7
D8:	CALL DESGN8
DJNZ R3,D8
D9:	CALL DESGN9
DJNZ R3,D9
first design is D7 , there is line MOV R3, #05 it means D7 will repeat 5 time, then D8 will execute, & after that D9,,
suppose D7 is running, and when we press the switch then repetition number of D7 should be infinite means when is switch pressed then only D7 should will execute, and when switch goes its earlier condition means off condition then design will repeat only five time, after it D8 will execute n after D9 by the chip.
this interrupt should work for every design.
sorry for my mistake, i think this is enough explanation..
[ Edited Fri Dec 19 2014, 11:35 pm ]
Sat Dec 20 2014, 03:28 am
For what you want,it is easier to not use interrupts.
If the pattern gets much more complicated,
using an interrupt may be better.
Don't enable interrupts and change your code to this.
D7:	CALL DESGN7
JNB P3.3,D7
DJNZ R3,D7
D8:	CALL DESGN8
JNB P3.3,D8
DJNZ R3,D8
D9:	CALL DESGN9
JNB P3.3,D9
DJNZ R3,D9
 ajay_bhargavsankalp_s like this.
Sat Dec 20 2014, 11:01 pm
D7:	CALL DESGN7
JNB P3.3,D7
DJNZ R3,D7
D8:	CALL DESGN8
JNB P3.3,D8
DJNZ R3,D8
D9:	CALL DESGN9
JNB P3.3,D9
DJNZ R3,D9
Thanks a lot sir, its working,
great support, quick response,thanks admin sir & co admin sir..
i've some queries more about this project..
first one is,
if i using 2051 chip then how can i use ANALOG COMPARATOR for blinking speed control of design by the external controller like potentio meter. and what would be code for it?
[ Edited Sat Dec 20 2014, 11:10 pm ]
Mon Dec 22 2014, 03:46 am
great support,
sankalp_s
Thank you.
first one is,
sankalp_s
The ANALOG COMPARATOR on the 2051 seems to be
just a comparator , that is , not programmable.
You will need extra hardware to use it.
I would suggest adding a 555 timer circuit that generates a
square wave controlled by a pot.
Then just measure the frequency or length of the square waves.
[ Edited Mon Dec 22 2014, 06:05 am ]
Mon Dec 22 2014, 10:22 pm
great support,
sankalp_s
Thank you.
first one is,
sankalp_s
but sir i have seen speed controlling in 2051 chip without 555 ic,
sir my second query is, there are three program in side the code:
for example in program 1st has three design, program 2nd has two design program 3rd has six design,
now i'm using any two pin for call these design. (ie.pin p3.2 & p3.3)
if no any pin is low then only program 1 will be run
if 3.2 then only program 2
& when 3.3 then only program 3
is this possible with JB & JNB instruction?
i've tried but only 1 program works,
could you please give me code for that.
