pickit 3 prgramming
i have done with a simple blinky program with MplabX and builded with XC8 compiler
i tried to flash the code with the PICKIT3 standalone tool..
it shows the following Error...
Program operation of program memory failed
Address 0x0 ,read 0x0 ,expected 0x3fff..
any one have idea how to solve it???
[ Edited Tue Jul 22 2014, 10:42 pm ]
Erase the Pic then do a blank test.
If it is blank try to program it again.
Can the Pickit3 read the Pics signature bytes and control bytes ?
If it is blank try to program it again.ExperimenterUK
i tried to read its getting the values . Erase also ok... ,verify is failed... blank check is ok...
Thanks let me try and get back to you.....
[ Edited Wed Jul 23 2014, 10:33 am ]
no still not programming
error:
programming of program memory failed
Does your programmer see the PIC as the right type ?
It could be to do with low voltage programming.
Do the config bits you read from the chip say it is set for
high or low voltage programming ?
Have you set your programming software for high or low voltage programming ?
What PIC is it ?
Have you set your programming software for high or low voltage programming ?ExperimenterUK
PIC16f882 i am using Standalone tool for programming...
how to select the high or low voltage programming does it have impact on programming...
what tool is it exactly? usually parallel program is high voltage programing and some of the serial programmers have feature of high voltage programming too. only difference is VPP is 12v instead of 5v or 3.3vajay_bhargav
pickit3 standalone programmer
i am using 5v for programming/.
Mark the connections to the PICKIT3.
