Discussion in "Project Doubts" started by    Peter_Parker    Dec 11, 2013.
Wed Dec 11 2013, 11:22 pm
Hey guys,
Just wondering can I use an 8051 chip to monitor someone's heartbeat and then sent the results via bluetooth to a pc/phone
There's kinda a thread on it here but its like 5 years old
Sat Dec 14 2013, 03:25 am
If you can deal with the detecting side of things it should be quite easy.
Serial Bluetooth adapters are cheaply available on Ebay.
Just send your results as a serial message to the PC.
Mon Dec 16 2013, 02:35 am
IR based heart rate sensor are easy to make.. As ExperimenterUK said, if you are done with reading from sensor then you can send it over bluetooth via a serial bluetooth module with serial port profile.
Thu Jan 30 2014, 10:59 pm
Thanks guys,thats good to hear,its been a while since I've done any building/programming.
Ya I'll just work on reading from the sensor first before I move onto the bluetooth side of things.
Can you guys recommend any heartbeat project that I could follow?
(Preferably one using Keil uvision as I've used that before)
Wed Feb 12 2014, 02:41 am
There are lots of posts on heart rate monitor on forum. Just do a search... Here are few for reference:
http://www.8051projects.net/t44530/8051-discussion-forum/heart-beat-rate-meter.htm
http://www.8051projects.net/tags/heartbeat-sensor-using-infrared-led
http://www.8051projects.net/t44908/electronics/heart-beat-sensor.htm#post_44922
http://www.8051projects.net/t49295/8051-discussion-forum/heart-rate-monitor-sys-using-at89c2051source-code.htm
Thanks thats great,think I'll try this circuit
but instead of using the Sunrom sensor at input P1.0,I'll switch that for this
Would that be ok to do?
Wed Feb 19 2014, 09:41 pm
Did you find out it worked or not for you? I suggest you test output of circuit on Oscilloscope first.
Thu Feb 20 2014, 06:30 am
Still waiting on some parts to arrive but do you see a reason from the above schematic why it wouldn't work?
Thu Feb 27 2014, 12:15 am
Actually would anyone recommend a particular type of bluetooth adapter to go with the AT89S52 or are they all kinda the same
Thu Feb 27 2014, 11:14 am
mostly bluetooth modules are same. All you need to look for is SPP support.
Any progress on the sensor side?
Malcolmaccek
Wed Apr 24 2024, 01:21 am
