pic industrial and domestic timer
Mon Dec 02 2013, 01:34 am
Build I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\IDTPM for device 16F877A
Using driver C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin\picc.exe
Make: The target "I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\main.p1" is up to date.
Make: The target "I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\LCD162.p1" is up to date.
Make: The target "I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\delay.p1" is up to date.
Make: The target "I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\mystrings.p1" is up to date.
Make: The target "I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\877_eeprom.p1" is up to date.
Make: The target "I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\DS1307.p1" is up to date.
Make: The target "I:\pic industrial timer\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.p1" is out of date.
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.83\bin\picc.exe" --pass1 "I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c" -q --chip=16F877A -P --runtime=default,+clear,+init,-keep,+osccal,-download,-resetbits,-stackcall,+clib --opt=default,+asm,-debug,-speed,+space,9 --warn=0 -D__DEBUG=1 --double=24 --float=24 --addrqual=ignore -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 35.7 undefined identifier "RA4"
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 38.1 function declared implicit int
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 38.13 undefined identifier "LCD_clear"
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 39.1 function declared implicit int
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 40.1 function declared implicit int
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 40.17 function declared implicit int
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 42.1 function declared implicit int
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 45.18 function declared implicit int
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 45.37 function declared implicit int
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 53.38 undefined identifier "setstring"
Error [981] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 53.50 pointer required
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 54.38 undefined identifier "setstring"
Error [981] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 54.50 pointer required
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 58.35 undefined identifier "rlyonoff"
Error [981] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 58.53 pointer required
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 62.4 undefined identifier "RD1"
Error [981] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 66.30 pointer required
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 68.4 undefined identifier "RD0"
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 78.1 function declared implicit int
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 88.69 function declared implicit int
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 94.4 undefined identifier "RD2"
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 100.28 function declared implicit int
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 106.4 undefined identifier "RD0"
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 112.4 undefined identifier "RD1"
Warning [361] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 117.1 function declared implicit int
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 131.7 undefined identifier "RD2"
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 132.13 undefined identifier "LCD_clear"
Error [192] I:\pic industrial timer\IDT\MPLAB PROJECT\MPLAB PROJECT\MPLAB PROJECT\alarm.c; 146.4 undefined identifier "RA4"
Advisory[1] too many errors (21)
********** Build failed! **********
i only changed wht u instructed me
Mon Dec 02 2013, 01:45 am
Looks like issue with header file. Are you using MPLAB or MPLABx (new IDE)?
Mon Dec 02 2013, 02:27 am
Well he did a very awkward way of building code. He is including C file instead of header file. that might be causing issue. Probably the new Hi-Tech C compiler does not allow this. You need to work a little bit and create header file to add all the function prototypes to one header file that you can include it in all your C file.
e.g. for set_alarm function prototype will be
void set_alarm(void);
for LCD_send_packedbcd function
void LCD_send_packedbcd(unsigned char data);
You get it? errors coz probably of latest version of Hi-tech C.
Mon Dec 02 2013, 07:59 am
To be honest i dint understand what u sayed.I am not all that good in this
Thu Dec 05 2013, 05:07 am
Its really difficult to help you if you do not understand what I am trying to say. Its basic C that I am talkin about. You need to create header file thats it. Anyways let me see if I can create it for you.
Sat Dec 07 2013, 10:21 pm
I have been reading and i think i got an idea of what you are saying but i will greatly apreciate if you made one for me
Mon Dec 16 2013, 04:01 am
Here is the header file code, save it in a file name idt.h
Now make following changes in following files..:
877_eeprom.c
DS1307.c
LCD162.c
delay.c
mystrings.c
alarm.c
main.c
Add #include "idt.h" in all the above files.
And from main.c remove all the C files
Now once you done these modification, now add all the C files in the project so that they gets compiled. Hope it works for you
#ifndef __IDT_H__ #define __IDT_H__ // EEPROM void Eeprom_write(unsigned char address, unsigned char data); unsigned char Eeprom_read(unsigned char address); //DS1307 void rtc_init(void); void rtc_settime(unsigned char h,unsigned char m,unsigned char s); void rtc_setdate(unsigned char y,unsigned char m,unsigned char d,unsigned char w); void rtc_gettime(unsigned char *h,unsigned char *m,unsigned char *s); void rtc_getdate(unsigned char *y,unsigned char *m,unsigned char *d,unsigned char *w); // LCD void LCD_enable(void); void LCD_data(unsigned char ascii); void LCD_command(unsigned char ascii); void LCD_gotoxy(unsigned char x,unsigned char y); void LCD_string(unsigned char *lcd_string); void LCD_init(void); //mystring void LCD_send_packedbcd(unsigned char data); void LCD_timeset(unsigned char data,unsigned char position); unsigned char hex2bcd (unsigned char x); //Alarm void set_alarm(void); void set_time(void); #endif // __IDT_H__
877_eeprom.c
DS1307.c
LCD162.c
delay.c
mystrings.c
alarm.c
main.c
#include"877_eeprom.c" #include"DS1307.c" #include"LCD162.c" #include"delay.h" #include"mystrings.c" #include"alarm.c"
