Discussion in "PIC Microcontroller Discussion" started by    maann    Sep 22, 2013.
Thu Sep 26 2013, 10:00 am
33pF and 0.1uF (100nF) are ceramic. 2.2uF probably be electrolytic. 50V? well, depends where you're connecting that capacitor. For relay You need to to see what your load voltage is, depending on that use your capacitor.
Thu Sep 26 2013, 10:07 am
ajay,
do you have any de-bouncing circuit?,
our seven segment is bouncing... example, 1 then 8 and so on,
thankyou
Thu Sep 26 2013, 11:00 am
seven segment display does not need a de-bouncing logic or circuit. did you put circuit together?
Thu Sep 26 2013, 11:27 am
hmm we use another circuit for the application of project..
actually, aside from ur circuit, we are making another output, we decided to have a count up counter, with different circuit. but it is not connected to themicrocontroller.
we use, 74LS192 and74LS47, however the display bounces..
attached is the circuit that we use, there is no problem of the circuit, but only it bounces...
Thu Sep 26 2013, 01:19 pm
there should not be any issue with your counting coz you're using discrete chips for display and counting purpose. Make sure you're doing your coding correctly.
Give RESET signal at power up, then for counting up/down just give a pulse L->H->L.
