Discussion in "PIC Microcontroller Discussion" started by    abdul991    May 28, 2013.
Tue May 28 2013, 03:44 pm
I'VE TRIED 2-3 COMBINATIONS WITH BRGH, 8BIT AND 16 BIT SPBRG..
I'M UNABLE TO TRANSMIT A STRING TO HYPERTERMINAL...
ALL I GET AT THE PC IS GARBAGE VALUES
#pragma config PWRT = OFF
#pragma config WDT = OFF
#pragma config DEBUG = OFF,LVP = OFF //,STVR = OFF
#include <P18F4550.h>
                    // USING 12MHZ CLOCK
#include<stdio.h>
#pragma <string.h>
#pragma <stdlib.h>
/*     SIMPLE UART SERIAL TRANSMIT   */
void SerTx(unsigned char c);
void  Delay(unsigned char a);
     int i;
     char c[] = "DIGI ELECTRONICS";
     Delay(250);
     TXSTA = 0x24;   //   HIGH SPEED BRGH =1 for asynchronous , tx enable settings
   	 SPBRG = 77;  //for BRGH =1,12mhz baud rate.
	 TXSTAbits.TXEN = 1;
	 RCSTAbits.SPEN = 1;
     BAUDCON = 0x40;
       Delay(250);
        for(i=0; i<strlen(c); i++)
       SerTx(c[i]);
       //sprintf(str,"the string is");
   int i,j;
   for(i = 0; i < a; i++)
   for(j = 0; j < 255; j++);
	while(PIR1bits.TXIF == 0);
	TXREG = c;
Tue May 28 2013, 10:28 pm
What baud rate are you aiming for ?
12MHz is an odd crystal for a PIC, are you sure its 12MHz ?
Wed May 29 2013, 10:07 am
there is a table given for baudrate generation in PIC datasheet. Did you try some of those values?
Fri May 31 2013, 05:47 pm
yes i'm sure its 12 MHz and i've tried various combinations if baudrate table
// TRIED FOR HSPEED BRG AND 16 BIT
     SPBRGH=0x01;
     SPBRG =0x36;
     TXSTA = 0x24;
     BAUDCON = 0x48;
     RCSTAbits.SPEN = 1;
	 TXSTAbits.TXEN = 1;
// FOR BRG =0 , 16 BIT ASYNCHR
     SPBRGH=0;
     SPBRG =77;
     TXSTA = 0x20;
     BAUDCON = 0x48;
     RCSTAbits.SPEN = 1;
	 TXSTAbits.TXEN = 1;
and the thing is i'm getting same kind of junk values for every combination i tried above.. pl check the attachment
Fri May 31 2013, 11:15 pm
PICs have various clock sources and dividers outside of the baud rate registers.
Often they are set by the compiler or even the programmer.
What software are you using ?
Please post the full code you are trying to work at 9600 baud.
Actually the srceen shot looks close to working.
Try different baud rates in Hyperterminal, you should get a match.
 abdul991 like this.
Sat Jun 01 2013, 04:29 pm
i assumed the same( as ExperimenterUK : Actually the srceen shot looks close to working...)
i tried different baudrates with -7 to +7 of the values i calculated.....
but didn;t get the o/p... i think the capacitor values for the xtal used has to be changed according to the datasheet..
not sure.... But 12Mhz Xtal is working good as the same gives perfect o/p for the PIC18f452.
Ii've entire code is given already
Sun Jun 02 2013, 07:31 pm
here is the equation to find baudrate generator value for uart..
For a device with FOSC of 16 MHz, desired baud rate of 9600, Asynchronous mode, 8-bit BRG:
Desired Baud Rate = FOSC/(64 ([SPBRGH:SPBRG] + 1))
Solving for SPBRGH:SPBRG: X = ((FOSC/Desired Baud Rate)/64) – 1
example @16Mhz for 9600bps:
X = ((16000000/9600)/64) – 1
X = [25.042] = 25
Calculated Baud Rate = 16000000/(64 (25 + 1)) = 9615
Error = (Calculated Baud Rate – Desired Baud Rate)/Desired Baud Rate
Error = (9615 – 9600)/9600 = 0.16%
Mon Jun 03 2013, 11:58 pm
Try flashing an LED, one for a second off for a second.
If the flash rate is wrong ,it probably means you have a clock rate selection error.
Or your program is wrong
Tue Jun 04 2013, 02:42 pm
flashing LED works perfectly...
so you mean to say problem is with the code.. i don't know where..?
Or
Is 12Mhz not compatible?
I'm skeptical on the capacitor use for oscillator circuit where i was using 33pF for 18F452..
Do i have to change capacitor as per the datasheet of 18f4550 mentioned in page 25 under Oscillator Configurations
Tue Jun 04 2013, 09:47 pm
Or
abdul991
Actually I should have said flash an LED using a timer.
Can you post the code you used.
If you use a built in delay or a loop it may not mean anything.
If the LED flashes at the calculated rate the crystal must be working at the right speed.
I think your value of 77 is correct, and should be accurate enough to work.
Try using the attached serial program on your PC
Bobbyerilar
Thu Mar 28 2024, 08:08 am
pb58
Thu Mar 28 2024, 05:54 am
Clarazkafup
Thu Mar 28 2024, 02:24 am
Walterkic
Thu Mar 28 2024, 01:19 am
Davidusawn
Wed Mar 27 2024, 08:30 pm
Richardsop
Tue Mar 26 2024, 10:33 pm
Stevencog
Tue Mar 26 2024, 04:26 pm
Bernardwarge
Tue Mar 26 2024, 11:15 am
