how to dispaly the a/d value from PIC16F877 using visual basic in digital value
Tue Mar 04 2008, 01:30 pm
The previous USART_Write(volts_out) would send out the value volts_out which had been declared as char hence only rounded off values(ie1,2,3,4,5) would be sent instead of say 1.87 or 2.54 etc.It was only for checking proper working.
The actual value received by the adc,which is an integer (2bytes) is split into two bytes and sent to the PC as Low_byte and Hi_byte.In the PC you can then 'join' the 2 bytes to the original int and then convert it to the appropriate voltage reading to be displayed. Hope it's clear.
I would suggest doing things step by step.First program the PIC and see if the LED's are working correctly.Then use Hyperterminal and check if the serial code is OK.Finally make the VB program.
Tue Mar 04 2008, 08:54 pm
hmm im trying it right now, and it can't light the leds on... does something in my circuit is wrong? the schematic diagram of my pic was posted before here. kindly check it sashjoseph, ive changed the ADCON1 to ADCON0, so the input will be put in AN0 in pin number 2, am i right?
Tue Mar 04 2008, 10:48 pm
heres my code and its working, i can light the leds now..... hope you can add the necessary codes for transmitting the signal to the serial port... pls help...
int limit=512;
int value;
TRISA=0xff; // Configure PORTA as analog input
TRISB=0; // Configure PORTB as output
PORTA=0;
PORTB=0;
ADCON0=0b10000000;
ADCON1=0b10001110;
ADCON0.ADON=1; // Enable ADC
for(;;)
ADCON0.GO=1;
Delay_us(10);
value=Adc_Read(0);
if(value>=512) // value is greater or equal to 2.5V
PORTB.F0=1;
PORTB.F2=1;
PORTB.F4=1;
PORTB.F6=1;
Delay_ms(100);
PORTB.F0=0;
PORTB.F2=0;
PORTB.F4=0;
PORTB.F6=0;
Delay_ms(100);
else if(value<512)
PORTB.F1=1;
PORTB.F3=1;
PORTB.F5=1;
PORTB.F7=1;
Delay_ms(100);
PORTB.F1=0;
PORTB.F3=0;
PORTB.F5=0;
PORTB.F7=0;
Delay_ms(100);
Delay_ms(3000);
and pls help me in my vb program... here is my first vb program...
Private Sub CmdExit_Click()
If MSComm1.PortOpen = True Then
MSComm1.PortOpen = False
End If
End
End Sub
Private Sub Form_Load()
MSComm1.InputLen = 0
MSComm1.CommPort = 1
MSComm1.Settings = "9600,N,8,1"
End Sub
Private Sub Timer1_Timer()
Dim BytesToRead As Integer
Dim value As Variant
BytesToRead = 1
Do
DoEvents
Loop Until MSComm1.InBufferCount = BytesToRead
value = MSComm1.Input
Text1.Text = (((Asc(value) * 0.01) * 230) / 2.5) & " Volts AC"
End Sub
int limit=512;
int value;
PORTA=0;
PORTB=0;
ADCON0=0b10000000;
ADCON1=0b10001110;
for(;;)
ADCON0.GO=1;
Delay_us(10);
value=Adc_Read(0);
PORTB.F0=1;
PORTB.F2=1;
PORTB.F4=1;
PORTB.F6=1;
Delay_ms(100);
PORTB.F0=0;
PORTB.F2=0;
PORTB.F4=0;
PORTB.F6=0;
Delay_ms(100);
else if(value<512)
PORTB.F1=1;
PORTB.F3=1;
PORTB.F5=1;
PORTB.F7=1;
Delay_ms(100);
PORTB.F1=0;
PORTB.F3=0;
PORTB.F5=0;
PORTB.F7=0;
Delay_ms(100);
Delay_ms(3000);
End If
End
End Sub
End Sub
BytesToRead = 1
Do
DoEvents
End Sub
