Discussion in "Project Addition or Changes" started by    pH    Mar 28, 2012.
Wed Mar 28 2012, 08:29 am
i have gone through the GREEN BEE projects and i really feel we should have an extension , so everyone please give in your ideas and suggestions for making a really practical application !!!
[ Edited Thu Aug 02 2012, 06:07 am ]
Sun Jul 29 2012, 03:43 pm
sir, i wnt to ask that, can i add water level indicator in the well in this project?
using same microcontroller will it be possible or not?
as i m new in microcontroller i dont have much information regarding this...
so the green house owner can see the water level in the tank on the lcd..
please tell me will it be possible to add this in in house green house project ?
Sun Jul 29 2012, 03:49 pm
f i want to add this circuit in my project.. then please provide the circuit diagram and necessary additional code for it..
thank you....!!
Mon Jul 30 2012, 07:08 am
@ vicky222
yes water level can be indicated using a micro controller or using any general ic
Tue Jul 31 2012, 07:40 pm
@ majoka; sir i want to add this in in house green house project..
can i do this on same circuit? along with all other sensors.. that is i am asking...
Wed Aug 01 2012, 01:44 pm
i use this once its work
Wed Aug 01 2012, 04:30 pm
@ajay and majoka:
thank you sir..:-)
i will try to add one more sensor in in house green house project.. i.e. Water level detector in tank..
From which water is given to crops..
Thank you.. Will try it..
And let u know..
Thu Aug 02 2012, 11:14 am
finally some R&D on in house green house , good to see , if this doesnt work tell me , i will give u my circuit
 vicky222 like this.
Thu Aug 02 2012, 02:59 pm
@ph: thank you..!
Is ur circuit different?
Plz tell me..
Can you attach ur circuit here..?
