Keyboard interfacing the Propeller LED Display
AT89S2051 is different. I was actually talkin about P89V51RD2 anyways... you can surely replace C2051 with S2051. The ISP circuit are available online, check here:
http://dybkowski.net/content/en/node/15
http://ikalogic.com/isp.phpAjay Bhargav
thanks for that.. Never thought it would be that easy! so we just have to connect those pins to the mosi, miso, sck & rst pins of the microcontroller?! Great!
Interrupts are an "add on".
The port works as usual, but you only see changes if you enable interrupts.
Other pins are more complex.
EG..if you enable the serial port, the TX/RX pins are controlled by the
serial hardware.
Actually I'm assuming that is the case
It may not always be true, but I never never tried to use a pin for two purposes
at once, it is hard enough doing one thing at onceExperimenterUK
I was asking to make a continuity in the input port. I mean, P3.2 is being used as interrupt while propeller display is running. So, while inputting the new sequence, i can just disable that interrupt & use p3.0 to p3.5 & hence get the 6 input lines continuously. So then programming will be easy.
Use Proteus to build a test circuit... it saves a *lot* of time.ExperimenterUK
Have heard of it, but haven't used it. Will check it out for sure.
nitheeshas
Search on forum you might be lucky make sure you dont get addicted to that software lol!
Search on forum you might be lucky make sure you dont get addicted to that software lol!Ajay Bhargav
man that software is really awesome! *no words to say*
About the programmer, i made the programmer shown in link below. I couldnt get 74LVC244 nor the AND gate ICs which were shown in the links you posted. I bought 74LS244, thinking it would be fine to use in circuit shown in the 1st link, but anyways, i searched for an ISP programmer that is using 74LS244 & got this link. You think it would be fine?
http://www.mytutorialcafe.com/Microcontroller%20Programmer%2089S51.htm
Also, i saw this line in the 2051 datasheet in the ISP section: "SCK frequency should be less than (XTAL frequency)/8."
How can we know the SCK frequency?
[ Edited Sun Feb 05 2012, 10:11 pm ]
yes this link is fine and it is working programmer
OR suggest some alternatives for S2051....
[ Edited Thu Feb 09 2012, 09:33 pm ]
u can use at89c2051
s2051 and c2051 is same things
see these attachments may be u find i t useful
But the problem is that there isn't any 8051 programmers available for me, in order to burn the firmware to the master microcontroller(in Easy downloader). That is why Ajay bro advised me to use a microcontroller that supports ISP so that a simple programmer could be built, which dont require a master uC. I have only ATMEGA8 & ATMEGA8535 programmers. Do you know any C2051 programmers that are using these uC as master?
The USBASP uses ATMEGA8, but i think its for ISP supported microcontrollers only, right?
