Discussion in "Project Addition or Changes" started by    Shehwar    Aug 19, 2011.
Thu Aug 25 2011, 04:00 am
i meant that instead of using so many wires to connect, i would rather prefer to use a single pcb with etched patterns on it.
I was just trying to improve presentation.:)
Fri Aug 26 2011, 11:13 pm
thats everything on you.. you can make it as you want provided you keep the original circuit intact do share your finished hardare with us.. photos and vids
Mon Sep 19 2011, 09:28 pm
hey guys i having big problems.:(
i tried to make the propeller display again. But i am not getting output. When i connect supply to the circuit, i just get fast blinking leds, With no particular pattern. The new one i tried is on single pcb and a small one for the interrupter module on the other side.i will upload them soon. Please help guys.what should i do?
Tue Sep 20 2011, 03:31 pm
@ Shehwar
ru try it before improving
is at that time it was running properly
is pattern is not particular when moving or in normal case
is interrupts working properly
Tue Sep 20 2011, 11:08 pm
can you post a picture of your hardware?
Tue Sep 20 2011, 11:59 pm
i tried to make the same project again. But i tried to make using single etched pcb. And mounting supply on board.
now i dont know whether or not interrupter is working or not during rotation. But when i tested the ckt it worked fine.
there is no particular pattern. The leds appear to be switching very fast and somewhat periodically. But when i rotate it, it seems as if all of them are on. ...:(
what should i do ?
Wed Sep 21 2011, 12:06 am
are you testing it without rotation?? What is the RPM of motor you're using?
Wed Sep 21 2011, 12:17 am
i am sorry bro. I am having trouble uploading images. I will mail you the files .pcb and pdf files now.
Wed Sep 21 2011, 12:20 am
I dont think its the problem with PCB. All i am saying is.. there must be a small thing missing in the loop. try to run your motor a bit slow and see if you get something understandable and visible..
Wed Sep 21 2011, 10:36 pm
@ Shehwar
what crystal value ur using
Williamjaf
Tue Apr 16 2024, 12:25 pm
best_yyPa
Tue Apr 16 2024, 09:42 am
ErnestoExpop
Tue Apr 16 2024, 02:57 am
Jamesclepe
Mon Apr 15 2024, 11:10 am
Aliciaelora
Mon Apr 15 2024, 07:59 am
btaletvpcu
Mon Apr 15 2024, 04:36 am
UbvpwcTib
Mon Apr 15 2024, 03:13 am
AmyJow
Sun Apr 14 2024, 11:54 pm
