Discussion in "Embedded GSM Development" started by    galapacos    May 13, 2011.
Sun May 15 2011, 02:13 pm
terminal 2 Rx pin is connected to Tx of pic it is ok
remove its Tx pin because ur not using it
use another hyper terminal connect that Rx pin with Rx pin of pic now on this terminal u can see the response of mobile
AT u see is that is sent by the pic ur not seeing the response of mobile in response of AT.
Sun May 15 2011, 05:17 pm
yes i did them, now can i communicate proteus simulation with laptop's COM port which i connect C55?
Sun May 15 2011, 06:29 pm
Sun May 15 2011, 09:13 pm
yes.. if your phone is using com1 then set your compim also as com1...
Sun May 15 2011, 09:40 pm
but my phone is using com 5,6,8,9 and compin show meonly com1,com2,com3,com4 there are no other coms, im changin them to my coms it becomes default again :S
Sun May 15 2011, 09:52 pm
go to device manager and edit the port setting of your phone so that you can point it to any ports available of the compim..
[ Edited Sun May 15 2011, 09:54 pm ]
Sun May 15 2011, 10:25 pm
ok i did your comments, but i cant see the response of "AT". Is that about delays in C program?
Sun May 15 2011, 10:42 pm
the last c code is:
Sun May 15 2011, 11:53 pm
i changed code to send sms, i send AT with hyperterminal then gets OK, after all in simulation program i send only AT+CMSS=1, sms sent but i want to see "AT" ,"OK" then "AT+CMSS=1" one by one in proteus simulation. how can i do that. thx.
Mon May 16 2011, 06:59 am
what did you do?
first start a simple program that would transmit AT to the phone if you can see the OK response of the modem.
in your protues monitor the rx and tx pins so that you can verify if the mcu is transmitting the command and if modem is replying the command sent by the mcu..
DadddyuricT
Tue Jul 02 2024, 11:19 am
VernonInips
Tue Jul 02 2024, 12:37 am
AmadoJelay
Mon Jul 01 2024, 01:25 pm
DonaldSit
Sun Jun 30 2024, 09:46 pm
Glubren
Sun Jun 30 2024, 07:20 am
Heathboype
Sun Jun 30 2024, 04:38 am
Jeremiahmer
Sun Jun 30 2024, 12:11 am
ZamfoMig
Sat Jun 29 2024, 06:01 pm
