Discussion in "Project Addition or Changes" started by    punit01    Feb 3, 2011.
Sun Feb 13 2011, 12:48 pm
thankooo so mch.. "tussi great ho sir ji..."
i'll solve my problem of PCB layout at my own... can u do one more thing 4 me... i need correct circuit diagram of that... its not clear in the package...
thanks again...
Sat Feb 19 2011, 04:54 am
thanks again...
punit01.sattani
I don't think we have any more circuit diagrams.
By "clear" do you mean you actually cant read them or that they don't give you
the information you want ?
Certain details are left off, such as the reset circuit, but if you make sure that all key pins
are connected, I think you can work it out.
Sat Feb 19 2011, 01:13 pm
yes, the image is not clear.. i mean its quite blurd or i m not able to see, which pin is connected to which... i tried to set its brightness, contrast and colors bt its not being proper...
Sun Feb 20 2011, 02:42 am
punit01.sattani
There must be a problem with your software.
I can enlarge the image in "Windows Picture and Fax Viewer" to see as much detail as I want.
Try viewing in Photoshop or similar
[ Edited Sun Feb 20 2011, 02:45 am ]
Fri Mar 18 2011, 05:35 pm
Dear Sir, I tried a lot for the layout but i m not able to complete this.. even i tried to magnify the image of schematic, bt i m not able to get the information...
plz help me out...
Fri Mar 18 2011, 08:32 pm
plz help me out...
punit01.sattani
Do you compllete your hardware section for evm???
I also do the same evm..In first time, it request the password...BUT ACTULLY I DONT KNOW THE PASSWORD..SO I DISCONNECTED IT FROM SUPPLY AND REFER THE PROGRAM..BUT AFTER THAT WHEN I GIVEN SUPPLY AGAIN ,THE LCD DISPLAY SHOWS ONLY SQUARES[NOT SHOWN ""ENTER PASSWORD"" COMMAND ]!!!
DO U HAVE ANY IDEA ABOUT THIS PROBLEM??
IS IT RELATED WITH THE INITIAL EPROM VALUE?????
PLZ HELP ME.....
Fri Mar 18 2011, 08:40 pm
punit01.sattani
Is this picture clear???
Fri Mar 18 2011, 10:21 pm
is this image is valid for both control and ballot unit..??
Fri Mar 18 2011, 10:48 pm
Iit shows the power supply unit and one microcontroller board.
The output is taken from each port.We can connect these port to any points.So in general ,we can use it as either control or ballot unit...
Mon Apr 04 2011, 10:09 am
Dear Sir,
I tried a lot but i m not able to design the layout of the project, plz suggest something...
utaletxcyw
Wed Apr 17 2024, 10:21 am
Anthonyvab
Wed Apr 17 2024, 08:48 am
RobertCix
Wed Apr 17 2024, 06:46 am
