Discussion in "Project Addition or Changes" started by    punit01    Feb 3, 2011.
Thu Feb 03 2011, 11:30 am
hello everyone, specially ajay sir...
i have downloaded "electronic voting machine project" from this site... everything is fine.. but the code includes a 6 digit security code... if i wanna use this project i'll hv 2 enter this code on initialization...
plz give me dat, so dat i can make it complete...
thanks in advance....
Sat Feb 05 2011, 04:08 pm
There are two voting machine projects on website. Which one you're referring to?
 punit01.sattani like this.
Sat Feb 05 2011, 10:14 pm
it is, in which we hv used ballot n control units.. i think it was posted by BINU, i also downloaded d copy of another evm bt i was looking like same as the previous one....
thanks 4 responding...
Sun Feb 06 2011, 04:32 pm
well i think you downloaded the one done by geetika and group. I will take a look at it once again. coz they showed me the working thing. Thanks for confirming again.
Mon Feb 07 2011, 10:26 pm
plz do inform soon... waiting 4 u :-)
Tue Feb 08 2011, 11:52 pm
sure punit, gimme some time... or can you do a quick review and highlight the problems. so i can directly go and check them will save a lot of time. and everything will be quick.
Sat Feb 12 2011, 12:55 pm
sry sir i didnt get, actually the schematic circuit diagram is not very clear in image... when i m trying to design its layout, its being very complex... another thing is.. the project contains a folder name 'circuit' it is having 4 images including its layout on PCB, but its nt mentioned dat whether the layout is of control unit or ballot unit...
and the last and vry serious problem is the security password, which will make the machine enable to work with the designer... its a 6 digit passwrd which will provide the security to the device after installing the prog into controller,
thankoo vry mch for responding...
Sat Feb 12 2011, 07:52 pm
it looks like there is problem with the archive. probably missing files? I need to look in backup drive. I hope i did not loose any data.
Did you mean that password is wrong or what? I do not understand the problem..
Sat Feb 12 2011, 11:20 pm
actually sir.. the man who has programmed the device has setted a password to access the machine, it is a 6 digit password.. but it is not anywhere in the project file...
when i'll complete the project and go for the testing it will ask for a password which i m not having...
Sun Feb 13 2011, 04:10 am
You are doing the Geetika group project
I don't think the PCB layout (or photo of assembled board) is actually for either schematic.
It has lots of connectors, so I'd say it is for an updated control unit,which would have items
like keyboards and displays plugged into it.
I found this in the source code
LIST1V: DB '0','1','2','3','4','5'	 ;PASSWORD OF VOTING MODE
LIST1R: DB '6','7','8','9','A','B'	 ;PASSWORD OF RESULT MODE
So the passwords you need will be
"012345"
and
"6789AB"
but don't tell anyone
[ Edited Sun Feb 13 2011, 06:32 am ]
utaletxcyw
Wed Apr 17 2024, 10:21 am
Anthonyvab
Wed Apr 17 2024, 08:48 am
RobertCix
Wed Apr 17 2024, 06:46 am
