Discussion in "ARM Development" started by    shyam    Dec 28, 2007.
Fri Dec 28 2007, 09:04 pm
topics to be discussed
1. selction of pins for different function.
2. setting PLL .
3.setting baud rate.
4.sending a byte of data.
5. receiving a byte of data.
6. using in interrupt.
7.difference between polled and interrupt mode
any thing u wanna add??
Fri Dec 28 2007, 09:28 pm
A small example programme to learn and test communication on hyperterminal . If till tomorrow i i could understand and test it on my board then i will feel bit satisfied
I believe you have made a proper list of topics further .
/* Include header file depending upon device been used */
#include<Philips\LPC2148.h>
void Initialize(void);
/* Macro Definitions */
#define TEMT (1<<6)
#define LINE_FEED 0xA
#define CARRIAGE_RET 0xD
/************************* MAIN *************************/
int main()
int i;
char c[]="Philips LPC";
Initialize()
/* Print forever */
i=0;
/* Keep Transmitting until Null character('\0') is reached */
while(c[i])
U0THR=c[i];
i++;
U0THR=LINE_FEED;
U0THR=CARRAIGE_RET;
/* Wait till U0THR and U0TSR are both empty */
while(!(U0LSR & TEMT)){}
/*************** System Initialization ***************/
void Initialize()
/* Initialize Pin Select Block for Tx and Rx */
PINSEL0=0x5;
/* Enable FIFO's and reset them */
U0FCR=0x7;
/* Set DLAB and word length set to 8bits */
U0LCR=0x83;
/* Baud rate set to 9600 */
U0DLL=0x10;
U0DLM=0x0;
/* Clear DLAB */
U0LCR=0x3;
[ Edited Sat Dec 29 2007, 12:36 am ]
Fri Dec 28 2007, 09:31 pm
I am looking forward for elaborate explanation on above subtopics . I do miss a lot words while typing a post and send it without checking . Please ignore myomissions.
Fri Dec 28 2007, 10:16 pm
wow u r really being quick i wud prefer to take a step a time...
moreover it is always better to set PLL than using its default value....
we will certainly try to get ur programme running....
in lpc as u might have noticed one pin can be configured to serve as 4 different funtions ex.
P0.1/RXD0/PWM3/EINT0 it is one single pin..
these functions lets say are fun0 fun1 fun2 fun3.
edited[
P1 in lpc21xx donot have special functions they have just fun0 and fun1.
things to note: we r not considering JTAG yet.. actually PINSEL2 is the PINSEL associated for P1 but
fun1 is related for JTAG debug.. Pins 0 through 15 of port 1 are not available.
in all cases fun0 is GPIO
by default (unless the functionality is selected all pins have this fun0).
the functionality can be configured by using PINSEL register (32 bit).
edited
thus it wud be clear by now that P1 does not have a PINSEL corresponding to it....
oops!! forgot pinsel2 plz ignore this line :blush
in binary the functions can be numbered as 0 00
1 01
2 02
3 03
each pin thus has two pinsel bits corresponding to it..
thus it wud be clear now .. for 32 bit Port 1 2 PINSEL registers wud be required..
they are PINSEL0 & PINSEL1.
now to ajay's code.
void Initialize()
PINSEL0=0x5;
writing 0x5 in binary we get.. 0x 01 01
the first two bits determine the function chosen
for P0.0 i.e. fun1 => UART0 TXD0
similarly the next two bits determine
the function chosen
for P0.1 i.e. fun1 => UART0 RXD0
thus ajay has selected his pair of RX/TX
!dance
!dance !dance
[ Edited Sat Dec 29 2007, 02:39 am ]
Fri Dec 28 2007, 10:43 pm
Slow and steady wins the race . You be slow and i am going to be steady . Ultimately we all will win.
Fri Dec 28 2007, 11:21 pm
[ Edited Sat Dec 29 2007, 02:43 am ]
Fri Dec 28 2007, 11:37 pm
please note P0.31 is GPO Port only i.e. cannot be configured as input!
it is generally used as USB good link led signal!!
Fri Dec 28 2007, 11:55 pm
2. setting PLL .
The PLL is used to multiply the external crystal frequency up to the maximum 60 MHz. It
is controlled by the constants M and P.
Within the PLL are two constants which must be programmed in order to determine the clock for the CPU and AHB. This clock is called Cclk. The first constant is a straightforward multiplier of the external crystal. The output frequency of the PLL is given by:
Cclk = M x Osc
In the feedback path of the PLL is a current-controlled oscillator which must operate in the range 156MHz – 320
MHz.. The second constant acts as a programmable divider which ensures that the CCO is kept in specification.
The operating frequency of the CCO is defined as:
Fcco = Cclk x 2 x P
well i had already submitted a design for lpc2138/48 if u find it ... u wud notice the crystall of frequency 14.745 Mhz.
so
- System should run at max. Frequency (60MHz) [limit: max 60 MHz]
- Choose multiplier M=4
so cclk = M * F_OSC= 4 * 14745000Hz = 58980000 Hz
- F_CCO must be inbetween the limits 156 MHz to 320 MHz
datasheet: F_CCO = F_OSC * M * 2 * P
- choose devider P=2 => F_CCO = 14745000Hz * 4 * 2 * 2
= 235920000 ~=236 MHz
now you can choose the multiplier and devider value for PLL depending on your crystall
Sat Dec 29 2007, 12:28 am
please note:
There are two PLL modules in the LPC2141/2/4/6/8 microcontroller. The PLL0 is used to
generate the CCLK clock (system clock) while the PLL1 has to supply the clock for the
USB at the fixed rate of 48 MHz. Structurally these two PLLs are identical with exception
of the PLL interrupt capabilities reserved only for the PLL0.
so @ ajay...
u should configure the PLL first...
lets see how to do it=>>>
Sat Dec 29 2007, 01:27 am
take a look at the code...
#define FOSC		14745000
 /*on board crystall frequency */
#define PLL_M		4
 /*Cclk = M x Osc  Cclk =60Mhz  Osc 14.745 Mhz M~4   */
#define MSEL		(PLL_M-1)
#define PSEL0 		5
 /*see user manual PLLCFG*/
#define PSEL1 		6
 /*see user manual*/
#define PLLE		0
 /*see user manual PLLCON*/
#define PLLC		1
#define PLOCK		10
 /*see user manual PLLSTAT*/
#define PLL_FEED1	0xAA
 /*constant*/
#define PLL_FEED2	0x55
 /*constant*/
void systemPllInit(void)
        // --- enable and connect the PLL (Phase Locked Loop) ---
	// a. set multiplier and divider
	PLLCFG = MSEL | (1<<PSEL1) | (0<<PSEL0);
	// b. enable PLL
	PLLCON = (1<<PLLE);
	// c. feed sequence
	PLLFEED = PLL_FEED1;
	PLLFEED = PLL_FEED2;
	// d. wait for PLL lock (PLOCK bit is set if locked)
	while (!(PLLSTAT & (1<<PLOCK)));
	// e. connect (and enable) PLL
	PLLCON = (1<<PLLE) | (1<<PLLC);
	// f. feed sequence
steps to initialise pll
1.
remember MSEL = M -1 cause to remove devide by zero error... the MSEL value is always +1 there will be other instances too... we will discuss as they come across..
2.
// b. enable PLL
PLLCON = (1<<PLLE);
every time you make a change in PLLCON register be sure to follow it up with a feed sequence to affect the changes done... else there wud be no effect and old status will be in effect... :-)
so..
// c. feed sequence
PLLFEED = PLL_FEED2;//mandatory
3.
4.
// f. feed sequence
now your system is ready to work at the desired PLL frequencies... remember PLL settings shud be carefully done... as they help generate the frequencies for almost all on chip devices...
note: dont worry writing this function in your every code.. it will remain same as long as u use the same crystall...
[ Edited Sat Dec 29 2007, 02:31 am ]
 saowangru like this.
Malcolmaccek
Wed Apr 24 2024, 01:21 am
