Discussion in "Project Addition or Changes" started by    ajit_foryou87    Dec 21, 2007.
Fri Dec 21 2007, 10:44 pm
hi im makin a temprature controller using 8952 and 1821.i wnt to implement GSM automation in it.that means it could send msgs to the operator regarding present temprature readings.cn u help me out.i dnt exactly knw how to interface a GSM modem and also the AT command programming
Fri Dec 21 2007, 11:02 pm
ok ...which modem r u using:-/
Fri Dec 21 2007, 11:42 pm
i have no idea abt the hardware modem.i knw the nokia AT command set.i have never used GSM modem.plz help
Fri Dec 21 2007, 11:52 pm
atleast you should select a modem for your project or tell which mobile phone you are going to use..
Fri Dec 21 2007, 11:56 pm
im gonna use nokia 1100
Sat Dec 22 2007, 12:03 am
hmm.. it does not support AT commands.. and FBUS protocol information is not available so far.. for this phone..
Sat Dec 22 2007, 12:29 am
wht if i use sony erricsson T150
Sat Dec 22 2007, 12:41 am
if it support AT commands then you can use it.. all you need is something that can give your controller an ability to send sms
so any phone with AT command and serial interface will work
 ajit_foryou87 like this.
Thu Jan 10 2008, 12:08 am
im using SIEMENS XT555 modem.
Thu Jan 10 2008, 12:22 am
so have you tested the AT commands? are they working on it or not?
