Digital clock code for SDCC and Using DS89C450 as Replacement for AT89C52
Discussion in "Project Addition or Changes" started by Arun Kumar V Feb 2, 2007.
Fri Feb 16 2007, 12:44 pm
Hello Rickey,
As you said, i tried compiling the Clock_Mod_1 code with SDCC, but it gives syntax errors:
SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.6.0 #4309 (Jul 28 2006) (MINGW32)
Compiling...
stdout: Broken pipe
C:/WINDOWS/DESKTOP/CLOCK_~3.C(67) : syntax error: token -> '=' ; column 14
C:/WINDOWS/DESKTOP/CLOCK_~3.C(68) : syntax error: token -> '=' ; column 14
C:/WINDOWS/DESKTOP/CLOCK_~3.C(69) : syntax error: token -> '=' ; column 14
-:0: error 103: code not generated for 'main' due to previous errors
C:/WINDOWS/DESKTOP/CLOCK_~3.C(178) : error 103: code not generated for 'ini' due to previous errors
C:/WINDOWS/DESKTOP/CLOCK_~3.C(187) : syntax error: token -> '=' ; column 14
C:/WINDOWS/DESKTOP/CLOCK_~3.C(188) : syntax error: token -> '=' ; column 14
C:/WINDOWS/DESKTOP/CLOCK_~3.C(189) : syntax error: token -> '=' ; column 14
C:/WINDOWS/DESKTOP/CLOCK_~3.C(190) : syntax error: token -> ';' ; column 19
C:/WINDOWS/DESKTOP/CLOCK_~3.C(193) : syntax error: token -> '=' ; column 22
C:/WINDOWS/DESKTOP/CLOCK_~3.C(193) : error 103: code not generated for 'busy' due to previous errors
Compile error! Output not generated.
Fri Feb 16 2007, 09:00 pm
Now try again
i think the header file you are using is not ok! not sure. just feel like
i updated the file compile again!
Wed Jun 20 2007, 07:09 pm
Hi Rickey
for Free Sample
Just Login to www.maxim-ic.com
and choose the product and order a sample
and the DS89C450 is really a very fast cpu
and with some extra feature so u have to modify the source to work with it
for Free Sample
