[solved]Auto door lock system with AT89c2051
Mon Oct 04 2010, 03:33 pm
here is the screens hot below after i first click the IC then after i left click it disappears.
Mon Oct 04 2010, 03:41 pm
i tried to change time ang am/pm but no luck.. now i;ll try to restart my PC
Mon Oct 04 2010, 03:45 pm
ur clicking on all over the diagram just click on ic that ic should get red not a keypad
in the pic it seems that keypad is also red
Mon Oct 04 2010, 04:04 pm
no i just click only the IC but the keypad also becomes red it seems that it flows from the wire.. lol
in the schematic theres no VCC on 8051. is that okay? will the compiler understand that if didnt put a vcc?
Mon Oct 04 2010, 04:23 pm
yes that is not a issue ok dear wait some time i eat launch
romel_emperado like this.
Mon Oct 04 2010, 05:06 pm
hi all Im very hapy now.. i successfully run the proteus and your progrma is working.!!!
now its easy to me to edit the program.. thanks man.. I will upadate this thread and post my final work here.. thanks so much.. God Bless all.. Long live!!
here is the trick i did:
i found out that the license date of proteus is expire last 2009 so i backward the date then reinstall the software....!! thanks!! hehe lol Im very happy.. ac ac
Mon Oct 04 2010, 05:27 pm
hi romel_emperado
i never get this type of problem i just correct the date and error removed anyhow u install it it is gud
i dnt want to misguide anyone i first run it in proteus and built code in keil then i upload u i dnt know where is mistake in code here is the simulation i do
any how if u get mistake in my code then tell me for my guideness
thanx
thanx
[ Edited Mon Oct 04 2010, 05:28 pm ]
Mon Oct 04 2010, 05:39 pm
hi majoka, your code works very fine and i dont have a problem on it....
its just the protues..
the proteus is now working fine with me.... the thing i need to do now is to edit the code into my convenience.. thank you sop much for the code.... i havent learn it anywhere in the web or school but i learn it from you.. thanks buddy..
Mon Oct 04 2010, 07:09 pm
hi majoka again.. it is possible if i modify the code for password purposes and the user can change the default password to their custom password without using external EEProm for the password storage of my AT89c2051?
