Discussion in "Project Addition or Changes" started by    tahirmaqsood    Sep 26, 2010.
Mon Nov 15 2010, 01:51 am
#61
Its working!!!
Thanks to everyone who helped me!!!
So here is my solution: Im cutting the images into 2 party to be desplayed as one. I know that there has to be another way, but I didnt find it The simulation work fine... Lets wait for the IRL-version
Okay - feel free to tryout -
" * " to start
" # " to enter after code-request
veryfycode " 1234 "
mastercode "12345 " written onto blocking-image
So far - so good.
Have a nice weekend!
Wawa
Mon Nov 15 2010, 04:18 am
#62
job well done wawa..!!
btw i tried fast LCD but i have doubt. how do i convert this this to hex? can i directly chage it to lets say 0x08 from &h08?
tae = 128, 8,   ' Image Table Name, Xbytes, N of Lines, 1026 bytes
&h00,&h00,&h00,&h08,&h00,&h00,&h00,&h00,&h00,&h00,&h04,&h00,&h00,&h00,&h00,&h00,
[ Edited Mon Nov 15 2010, 04:19 am ]
Tue Nov 16 2010, 02:21 am
#63
Yes - I did it with word.
Keep focus on changing the picures attributes to greyscale before converting.
 romel_emperado like this.
Wed Nov 17 2010, 06:18 pm
#64
well problem is you declared variable 'i' as unsigned char so it never goes beyond 255 and your loop expect it to be 504
declare i as unsigned int and see the result with code i posted let me know when its done. good luck!!
Wed Nov 24 2010, 12:25 am
#65
Hey!
I didnt change the code yet. Semms to wrk but now my ego starts to fight to make a bigger job... well - only some hours of work and some money to spend but to let the ego grow.... when its done
Seriously: I am thinking about implementing this codelock as start of a touchscreen-based interface...
hahaha - I need more then halp, I think
Thanks for your starting-up help till now
Regards
Wawa
Fri Nov 26 2010, 12:26 am
#66
Good luck wawa
you will get all the help you need. Keep working and post your updates.
Sun Nov 28 2010, 12:49 pm
#67
Dear MAJOKA
I try attach with 93c46
Without 3310 lcd work but with 3310 lcd not work plz ones again help me
thanks
Sun Nov 28 2010, 02:16 pm
#68
93c46 is an serial eeprom of 3 wire
why u need to connect it ru need to save password
u want to say that ur code is working with 93c46 but when no 3310 lcd
am i right ?
Sun Nov 28 2010, 04:50 pm
#69
Yes I want save password in eeprom
but I add commands in code for 3310 lcd then 8951 pin no data send to 93c46
I am checking in proteus
Mon Nov 29 2010, 12:05 am
#70
hello tahirmaqsood
upload Proteus files for my easiness
it mean u facing the problem only when u attach memory to 8051
then 8051 not store data on memory in normal
case when simple 3310 lcd is connected without memory its work well
store a password in an array as in previous codes u do
after that when user press enter key then store this array into eeprom at once that will be an easy approach
