Discussion in "Project Addition or Changes" started by    tahirmaqsood    Sep 26, 2010.
Wed Sep 29 2010, 12:20 am
i do not define that i adjust spaces in such a way that when any key press it start to new line becoz lcd auto increment the address for next character let say a string end at the end of 2nd line then the next character automatically display on next 3rd line i did this logic u can set it by calling a function given in library
Wed Sep 29 2010, 07:11 pm
Diar MAJOKA
again very thanks
my big problem solve with your help
Thanks
Wed Sep 29 2010, 09:04 pm
you are welcome always
[ Edited Wed Sep 29 2010, 09:05 pm ]
Mon Oct 04 2010, 09:02 pm
Dear MAJOKA
I have 2 problems more with this code .
1-if used ‘ * ‘ key one time then 2x16 LCD one digit delete but 3310 LCD all digit delete .
2-if power is off then new password is canceled and default password is set .
I want use internal EEPROM for this purpose Possible this?
Or used only external EEPROM ?
I am no idea used the EEPROM
Plz help me these 2 problems
Thanks
Mon Oct 04 2010, 10:51 pm
upload ur code that u edit so can help u better
at89c51 does not have internal eeprom so u have to use external eeprom
use at24c01serial eeprom it is sufficient for ur application
if u want to learn it i can provide u some sample codes
Tue Oct 05 2010, 12:03 am
with this code used ‘ * ‘ key 2x16 LCD one digit delete but 3310 LCD no digit delete .
plz send me eeprom sample code
Tue Oct 05 2010, 12:36 am
why didnt you take out other LCD code? i see its still lurking out there.. first remove that if you are not using 16x2 lcd.
Tue Oct 05 2010, 09:25 am
here i update code there was no code written for spaces on 3310 lcd
here r some samples for different eeprom
it is better option u use at24c01 for ur application it is better to handle at initial stage
Tue Oct 05 2010, 06:14 pm
Sir Ajay Bhargav
Thanks for replay attach 2x16 LCD only for code checking after the complete code 2x16 LCD remove
Dear MAJOKA
you r grate thanks for my help
Tue Oct 05 2010, 06:39 pm
ur welcome
 romel_emperadoWawa like this.
