Discussion in "Map Me Support" started by    VR6Pete    Oct 14, 2009.
Wed Oct 14 2009, 04:09 am
Version 1.3:
When attempting to import users, it just freezes, if I set the chunk size to 150, the first 150 users import, however after that, no more imports and it just freezes on " Loading user list, Please wait..."
I have 10,329 users I wish to import into this plugin.
Wed Oct 14 2009, 11:09 am
can you open this page on your site logging into admin account and tell me if its breaking anywhere..
yoursite.com/e107_plugins/mapme/mapxml.php?type=update
post a screenshot of where its breaking or if error comes in xml then do tell me that error. I think its the same encoding problem.
Wed Oct 14 2009, 03:38 pm
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
The character '<' cannot be used in an attribute value. Error processing resource 'http://www.vr6oc.com/e107_plugins/mapme/...
<uloc uid="421" location="<br>Bristol<br>Weston Super Mare" />
Thu Oct 15 2009, 01:32 pm
I will give you updated zip file by today can you test it for me?
and i think problem will be solved.
Thu Oct 15 2009, 03:17 pm
no problem, just let me know the link, and i'll test it later.
Fri Oct 16 2009, 12:01 am
Files are here:
www.8051projects.net/Beta/mapme.zip
Test it and let me know if everything is fine.
[ Edited Fri Oct 16 2009, 12:02 am ]
Fri Oct 16 2009, 04:41 am
Ok the map loads.
Notice longitute / latitude and zoom level not working though.
Also clusters that display a figure with 4 digits example: 1343 shift outside of the cluster image, it should me more central.
Also I have over 10,000 members, I know for a fact There are more people that live in Stoke-on-Trent, UK than thats currently displaying on the map, including me like for example, you see a cluster that displays 7 and when you zoom in, there is only a pin for 1 member, not the 7 i'd expect to be displayed?
Does that make sense? Here is the link to my members map:
http://www.vr6oc.com/e107_plugins/mapme/map.php
Settings are all default at present.
Fri Oct 16 2009, 04:44 am
importing is broken in the beta release, although the map displays fine.
/mapxml.php?type=update on my website produces a blank page.
and the import fails
I get a green tick next to loading the user list
The spinning icon is displayed on getting map information from mapme location and the progress bar displays, but with no percentage and no users display in the box
Pete
Fri Oct 16 2009, 04:46 am
Also, when you first load the map, it only displays the very top part of a cluster on the map, you should be able to see by looking at the above URL
Fri Oct 16 2009, 08:10 pm
well i cant help much with text going out of those clusters, coz cluster library is taken from web but i will still try..
i cant see your links coz i am not in admin mode. update is working fine for me. try to see the source of your blank page is it showing something?
and regarding zoomin, it shows 7 cluster and after you click on it you see 1. Reason is, it again form new clusters of markers if they are in valid range of defined pixels. so check carefully when you click on cluster showing 7, after zoom in it will show you maybe clusters with 1 marker count the total it has to be 7 or more if nearby marker is in range.
Michailqfh
Fri Mar 29 2024, 01:53 am
Bobbyerilar
Thu Mar 28 2024, 08:08 am
pb58
Thu Mar 28 2024, 05:54 am
Clarazkafup
Thu Mar 28 2024, 02:24 am
Walterkic
Thu Mar 28 2024, 01:19 am
Davidusawn
Wed Mar 27 2024, 08:30 pm
Richardsop
Tue Mar 26 2024, 10:33 pm
Stevencog
Tue Mar 26 2024, 04:26 pm
