Discussion in "8051 Discussion Forum" started by    jusal    Sep 26, 2007.
Fri Sep 28 2007, 10:18 am
ok sir... il find more what i can do for this research/project. it makes so hard for me to do alone since its my first time to do or make a project using microcontroller..tnx alot sir
Fri Sep 28 2007, 10:35 am
I am here to help don't worry.. Just go through the websites i gave you... take your mobile phone and connect it to serial port of your PC and monitor the data you are sending and receiving from your phone. This will help you to understand the protocol in a better way.
Fri Sep 28 2007, 01:20 pm
thank you so much sir...... i wish could make better of this project......god bless!
Tue Oct 02 2007, 03:14 am
sir,
iv gone through reading the links that u gave me..but i still have difficulties to understand some of those codes or memory addressing. but anyway sir, iv got somebody here to help me..by the way sir. instead of using 6110. can i use 5110/i for the project???
il wait for ur reply
Tue Oct 02 2007, 11:42 am
Hi Jusal,
the protocol used for 6110 can also be used for many other mobile phones like 3310, 3315 and so on..
as per GNOKII, models supporting 6110 Protocols are...
nk6100 driver:
Nokia 6110, 6130, 6150, 6190
Nokia 5110, 5130, 5190
Nokia 3210, 3310, 3330, 3360, 3390, 3410
Nokia 8210, 8250, 8290, 8850
Nokia RPM-1
Thu Oct 04 2007, 05:04 am
how do i get to know sir if the certain mobile phone using 9600baud rate,115.2 kbps, etc. serial communacation??
thank you sir!!
Thu Oct 04 2007, 05:14 am
i'll just wait your very nice reply sir!!! thanks a lot for ur help>>it gives me a big help for my study!!
Thu Oct 04 2007, 06:35 pm
FBUS is a standard defined by Nokia and it only works at 115.2KBps and MBUS works at 9600...
Fri Oct 05 2007, 05:32 am
what do you mean sir that is,"nokia 3310 does not allow sms in text mode"?.. please explain just a little bit about this..
thank you!!
Fri Oct 05 2007, 11:51 am
it means that you cannot send message in the command directly using ascii characters. The message/text that you want to send has to be converted to PDU format.
