Discussion in "Embedded GSM Development" started by    Has5n    Dec 25, 2008.
Thu Dec 25 2008, 02:10 pm
hi...i've got nokia3100....got its serial cable....now i need hyperterminal 2 send msgs to d set...bt i don know the its setting in pc...how 2 enable the modem options...which mobile softwares i need ....how 2 make the phone acting as modem...kindly guide...i m in deep trouble
Thu Dec 25 2008, 07:59 pm
nokia 3100 supports AT? I am not sure..
just try these settings in hyper terminal.. Baud: 9600, 8-n-1
type ATyou must get reply OK
if not that phone does not support AT commands.
Fri Dec 26 2008, 06:55 am
yes nokia 3100 supports AT commands....i tried everythingbrother....setting baud rates etc....the connection gets established....but i m unable 2 give any uinput from key board in the hyperterminal.......why this is so?....there may b a problem in the set....???...why do u thnk...
Fri Dec 26 2008, 11:16 pm
plz help me out guys...i need help...now i got nokia 6030.....bt thrs same problem...i m unable 2 give any input from keyboard....i mean my pc's COM port is workin f9....serial cable is new....are there any options tht need to b considered b4 givin any AT commands....plz help ..i m in deep trouble....
Fri Dec 26 2008, 11:33 pm
hi, to see the character you're typing on the terminal display you have to enable echo setting on. Its in file - properties - settings - ASCII setup and select Echo typed char.. and send line feed. hope this helps
Fri Dec 26 2008, 11:56 pm
thnx...now i m able 2 write AT ...bt its doesnt give any response...i mean after writing AT...and then hitting enter reutrns the keyboard cursor 2 first location of the same line...it doesnt give OK/ERROR in response...why this is so ??
Sat Dec 27 2008, 01:06 am
try this, open a new terminal make sure you're using the right comport. set the comport to 9600 8-N-1 and set the flowcontrols to hardware. do not set Echo or any other things, type AT and press enter. if you dont get respone back check the cable and the port
Sat Dec 27 2008, 04:18 am
first, turn of echo, use a simple serial cable. one end connected to PC com port and other end short pin 2&3 type something on terminal you must see what u are typing. if yes then ur port is fine.
try to use flowcontrol to both none and hardware see when u are getting response from phone.
Sat Dec 27 2008, 08:59 am
its doesnt give me any response on using flowcontrol 2 both none & hardware...sorry borhter i didnt get u 1st point....tht serial cable's other end short pin 2&3 type ??..... check out dis....do i need 2 1st perform dis(iI M USING NOKIA 6030) :
AT commands work on devices that have a built-in GSM modem. If there is one, you do not need to install virtual modem software on your PC. If you are using very old Nokia devices, you have to find out the DATA suite, not the PC Suite, for these devices (such as the Nokia 5110) to be able to use AT commands.
Make sure that you have installed the correct GSM modem driver on your PC. You can check it from Control Panel | System | Hardware | Device Manager. Check the Modems section. If you see something like "Nokia XY USB Modem" or "Nokia XY Bluetooth Modem", the device has a built-in GSM modem. If you don't have it, go to the Nokia Web site and download the driver from the product page of your device.
Sat Dec 27 2008, 09:05 am
see this pic....
http://wiki.forum.nokia.com/index.php/Image:Controlpanel_gsmmodem.png
so do i've 2 install PC SUITE software for usin nokia 6030 for AT commands....???
utaletxcyw
Wed Apr 17 2024, 10:21 am
