T610 interface with PIC16F877
Fri Nov 21 2008, 05:09 pm
Hello I have been trying to interface PIC16F877 with Sony Ericsson T610 but i cant. For a start up Iam just sending AT to the phone but i dont receive "OK" Iam using the serial data cable for the phone directly connected to the serial of the PIC
Sun Nov 23 2008, 06:59 am
According to Wikipedia and others,the 610 has Bluetooth ,Infrared and USB.
None of which are practical to connect to a PIC16F877.
I have seen no mention of a serial connection able to connect to a PC's serial port.
[ Edited Sun Nov 23 2008, 07:08 am ]
Mon Nov 24 2008, 02:22 am
ExperimenterUK, PC has got all that where as a tiny 8051 has just got a serial port so thats the only available option
Mon Nov 24 2008, 02:36 am
Sorry the code is as follows
#include <16F877.h> #device *=16 // This allows auto variables over location 0xFF and set #use delay(clock=4000000) #fuses XT,NoWDT #use rs232 (baud = 9600, BITS = 8, parity = N, rcv = PIN_c6, xmit = PIN_c7) #opt 9 #include "lcd_driver.c" #include<string.h> main (){ char str[3], okay[10]; char c[2]; int i; lcd_init(); // Initialise the LCD lcd_putc('\f'); // clear the screen lcd_putc("WELCOME"); // to test for LCD delay_ms(2000); lcd_putc('\f'); printf("AT"); putc(13); putc(10); for (i=0 ; i<4 ; i++) { c[i] = getc(); delay_ms(5); } delay_ms(100); for(i=0; i < 4 ; i++) { lcd_putc(c[i]); // Show what the phone sends on LCD delay_ms(100); } }
[ Edited Mon Nov 24 2008, 12:47 pm ]
Mon Nov 24 2008, 02:39 am
ExperimenterUK, PC has got all that where as a tiny 8051 has just got a serial port so thats the only available optionAjay
I meant was that as far as I can see this phone has no serial port meant for AT command
type communication.
It may have a serial link for flashing and special purposes, but that is not clear from what I have seen.
Of course Izzal's method may be fine, but it is worth checking before going further.
[ Edited Mon Nov 24 2008, 02:53 am ]
Mon Nov 24 2008, 12:45 pm
Pinouts says it has serial output, and my friends have used that phone in a project. Also people on forum like Abbas has used it too. So probably it has serial output
Mon Nov 24 2008, 04:07 pm
The Phone has serial output. I have already tested the AT-Commands using PC (Tera Term software) and it works fine. So after that I tried it with PIC16F877 but i could not communicate. I used MAX232 between the phone and PIC communication when it didnt work I used Transistor circuit but both methods failed.
Tue Nov 25 2008, 02:58 am
OK I'm convinced
A couple of points to consider, (actually three).
The 610 interface is 3 volts so may need a low voltage MAX232.
The data bits may need to be inverted.
I have seen the baud rate for the 610 given as 9600 and 115200.
An XP "9600" baud modem actually defaults to a com port speed of 115200.
