Discussion in "Project Addition or Changes" started by    shashank    Apr 17, 2007.
Tue Apr 17 2007, 06:24 PM
hello sir the error while compiling is as under.i am sending the output window result,
"build target 'simulator'
compilling rtc.c .....
compilling lcd.c ....
compilling project.c ......
linking ......
BL51 BANKED LINKER/LOCATOR V4.20-SN:K1PRP-MWVI9E
COPYRIGHT KEIL ELEKTRONIK Gm 1987-2001
"...\rtc.obj",
"...\lcd.obj",
"...\project.obj",
To ".....\project"
PRINT(".\project.m51") RAMSIZE(256)
***FATAL ERROR L211:I/O ERROR ON OUTPUT FILE:
EXCEPTION 0029H:ACCESS TO FILE DENIED
FILE:.../project
Target not created"
this is the output.you please go throuth it and tell how could we solve the error.
if you can then send me the hex file for ur source code my id is [email protected]
[ Edited Tue Apr 17 2007, 06:26 PM ]
Tags objtarget simulatorkeil elektronikrtchex file
Tue Apr 17 2007, 09:05 PM
first of all please do not create duplicate posts..
and if you have made changes in the code.. please be careful.. coz you are using too much of RAM.
if you want to add something, then add in such a way that.. u have sufficient RAM for the stack. otherwise controller will crash.
again Do Not create duplicate posts!
keep your problems in 1 thread.. so easy to track them for you. ok?
Tags duplicateplease be carefulcozstackcontroller
Sat May 05 2007, 07:03 PM
can i have the code for Digital Clock using ds1307 and 8051 (Without Alarm) in assembly..pls....
i found the code in C... can i pls have it in asm????
Sun May 06 2007, 07:02 AM
i think someone is already working on clock without alarm. see the post by pinky in the forum. ask her how much she has done.
No messages yet.
Guests: 173, Members: 0 ...
