Discussion in "8051 Discussion Forum" started by    xrxx    Apr 30, 2020.
Thu Apr 30 2020, 10:59 AM
BCD MULTIPLICATION
Assume that you have to 2 BCD numbers in 2 registers/memory locations.
Write a subroutine to multiply these 2 numbers and put the result in a different register set/memory location. The maximum number can be 9801 (99*99=9801). So you need 2 bytes to store 4-BCD digits.
Execute your program in the simulator and get screenshots at several steps during the execution.
Put your code and screenhots in a zip file seperately and submit the zip file as name_surname_id_hw1.zip
SWAP is good instruction to switch lower and higher nibbles (4-bits) in A.
Repeat the steps we follow on the paper.
Guys, can u help me for this? pleaseeeee
Thu Jun 11 2020, 06:27 AM
anudee
scena
Tue May 19 2020, 10:29 PM
Sat May 02 2020, 07:38 PM
Tamu Gurung
Wed Mar 25 2020, 01:39 PM
Tajammul
Fri Mar 13 2020, 10:36 PM
Fri Mar 13 2020, 12:55 PM
ABEBE
Rohitnani
Sat Mar 07 2020, 05:11 PM
Wed Feb 26 2020, 04:58 PM
Peter Parker
Sat Feb 01 2020, 10:12 AM
Pearl Olin
Hello,
Wed Jan 22 2020, 06:16 PM
MINU CHAUDHARY
Guests: 45, Members: 0 ...
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Wed Jul 01 2020, 11:07 PM
Mirza123 Avatar
Posted By Mirza123
Wed Jul 01 2020, 02:05 PM
Wed Jul 01 2020, 10:12 AM
wimac Avatar
Posted By wimac
Tue Jun 30 2020, 10:05 AM
Mirza123 Avatar
Posted By Mirza123
Tue Jun 30 2020, 08:39 AM
Tue Jun 30 2020, 08:34 AM
Mirza123 Avatar
Posted By Mirza123
Thu Jun 25 2020, 04:07 PM
Wed Jun 17 2020, 09:42 PM
cerouno Avatar
Posted By cerouno
Wed Jun 17 2020, 10:37 AM
Wed Jun 17 2020, 02:01 AM
