Discussion in "PIC Microcontroller Discussion" started by    sarrahjuzar    Feb 19, 2020.
Wed Feb 19 2020, 09:24 AM
I have a gsm module sim900a and dht22 connected to pic16f877a. Is it possible to interface gsm module to an IoT platform like Thingspeak to display the temperature data?
Fri Feb 21 2020, 09:45 AM
Yes you can do that.
1. Create a channel @Thingspeak and create fields for parameters that are going to be updated by your device. (in your case temperature and Humidity)
2. On your device generate HTTP GET request to update those fields.
Open socket connection to api.thingspeak.com @80
Send get request as follows:
GET /update?api_key=&temp=&humid=[cr][lf][cr][lf]
I used temp and humid as field names. You can change them to whatever you have created in channel
Please mind that cr (carriage return \r) and lf (line feed \n) are part of get request. So prepare the request carefully if you want everything to be success.
Thu Jun 11 2020, 06:27 AM
anudee
scena
Tue May 19 2020, 10:29 PM
Sat May 02 2020, 07:38 PM
Tamu Gurung
Wed Mar 25 2020, 01:39 PM
Tajammul
Fri Mar 13 2020, 10:36 PM
Fri Mar 13 2020, 12:55 PM
ABEBE
Rohitnani
Sat Mar 07 2020, 05:11 PM
Wed Feb 26 2020, 04:58 PM
Peter Parker
Sat Feb 01 2020, 10:12 AM
Pearl Olin
Hello,
Wed Jan 22 2020, 06:16 PM
MINU CHAUDHARY
Guests: 39, Members: 0 ...
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Wed Jul 01 2020, 11:07 PM
Mirza123 Avatar
Posted By Mirza123
Wed Jul 01 2020, 02:05 PM
Wed Jul 01 2020, 10:12 AM
wimac Avatar
Posted By wimac
Tue Jun 30 2020, 10:05 AM
Mirza123 Avatar
Posted By Mirza123
Tue Jun 30 2020, 08:39 AM
Tue Jun 30 2020, 08:34 AM
Mirza123 Avatar
Posted By Mirza123
Thu Jun 25 2020, 04:07 PM
Wed Jun 17 2020, 09:42 PM
cerouno Avatar
Posted By cerouno
Wed Jun 17 2020, 10:37 AM
Wed Jun 17 2020, 02:01 AM
