Discussion in "8051 Discussion Forum" started by    wounder    Jan 25, 2020.
Sat Jan 25 2020, 05:44 pm
I have a 8051 micro controller ,it has timer0,1,2,3 with different modes.
in timer0,mode0, i got a sample code (as shown below).
from that code
TH0_INIT=0xFC //5.0ms@XTAL=12MHz, Period = (10.85/2) ms@XTAL=22.1184MHz TL0_INIT=0x0F
both TH0,TL0 load with hex values..but could not derive these values from equation below .. (https://exploreembedded.com/wiki/5.8051_Timer_programming) Could you please tell me ,how these hex values derive ??
tick = (1/(Fosc/12)
tick = 12/Fosc$$ For Fosc == 11.0592Mhz, the tick time will be
tick = 12/11.0592M = 1.085069444us = 1.085us
Now the Timer value for the required delay can be calculated as below.
Delay = TimerCount * tick
Count = (Delay/tick)
RegValue = TimerMax- Count RegValue = TimerMax-(Delay/tick) = TimerMax - (Delay/1.085us)
RegValue = TimerMax-((Delay/1.085) * 10^6)$$
#include "SFR_Macro.h"
#include "Function_define.h"
#define TH0_INIT 0xFC //5.0ms@XTAL=12MHz, Period = (10.85/2)
ms@XTAL=22.1184MHz
#define TL0_INIT 0x0F
void Timer0_ISR (void) interrupt 1 //interrupt address is 0x000B
TH0 = TH0_INIT;
TL0 = TL0_INIT;
P12 = ~P12; // GPIO
toggle when interrupt
void main (void)
TMOD = 0XFF;
Set_All_GPIO_Quasi_Mode;
TIMER0_MODE0_ENABLE;
clr_T0M;
clr_T1M;
TH0 = TH0_INIT;
TL0 = TL0_INIT;
// set_ET0; //enable Timer0 interrupt
//enable Timer1 interrupt
set_EA; //enable interrupts
set_TR0; //Timer0 run
TH0 = TH0_INIT;
TL0 = TL0_INIT;
set_TR0;
while(!TF0);
clr_TR0;
P12 = ~P12;
TF0 = 0 ;
Sun Jan 26 2020, 09:35 am
For a 12MHz crystal using a normal divided by 12 clock.
For a 5mS delay I get
TH0_INIT=0xEC
TL0_INIT=0x78
What do you get ?
The program you posted uses polling and an interrupt to monitor the timer
and toggle P12, choose one, you can't (at least shouldn't) do both.
HenryLaf
Mon Apr 22 2024, 03:50 pm
bleradrar
Mon Apr 22 2024, 06:38 am
ppu-pro_ka
Sun Apr 21 2024, 07:39 pm
Infewow
Sun Apr 21 2024, 06:30 pm
