Discussion in "8051 Discussion Forum" started by    elt    Jan 7, 2020.
Tue Jan 07 2020, 07:06 PM
So i have just began learning programming micros and decided an 8051 would be a good start. I have followed the instructions found here: https://github.com/rgwan/librech551/wiki/Setup-SDCC-developing-environment-with-Eclipse
My problems/questions are that it gives me an error "make: *** [stc.rel] Error -1073741515"
and tells me build failed, how do i fix this? Also where do i find the .hex file if it builds successfully? Sorry if i make stupid questions but i'm an complete noob.
Tue Jan 07 2020, 08:18 PM
Not a stupid question.
Setting up "Eclipse" can be a nightmare, using "Make" can be a nightmare,
putting the two together is worse.
Eclipse is too complicated and you don't need its fancy features.
Download the free 8051 compiler from
http://www.keil.com/
It is used by most 8051 users.
[ Edited Tue Jan 07 2020, 08:23 PM ]
Sat Feb 01 2020, 02:20 PM
If you want to use a CH55x MCU there isn't any advantage to use Eclipse as there is no support for debugging on CH55x.
I've followed the guide here with success: https://github.com/Blinkinlabs/ch554_sdcc
Thu Jun 11 2020, 06:27 AM
anudee
scena
Tue May 19 2020, 10:29 PM
Sat May 02 2020, 07:38 PM
Tamu Gurung
Wed Mar 25 2020, 01:39 PM
Tajammul
Fri Mar 13 2020, 10:36 PM
Fri Mar 13 2020, 12:55 PM
ABEBE
Rohitnani
Sat Mar 07 2020, 05:11 PM
Wed Feb 26 2020, 04:58 PM
Peter Parker
Sat Feb 01 2020, 10:12 AM
Pearl Olin
Hello,
Wed Jan 22 2020, 06:16 PM
MINU CHAUDHARY
Guests: 40, Members: 0 ...
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Wed Jul 01 2020, 11:07 PM
Mirza123 Avatar
Posted By Mirza123
Wed Jul 01 2020, 02:05 PM
Wed Jul 01 2020, 10:12 AM
wimac Avatar
Posted By wimac
Tue Jun 30 2020, 10:05 AM
Mirza123 Avatar
Posted By Mirza123
Tue Jun 30 2020, 08:39 AM
Tue Jun 30 2020, 08:34 AM
Mirza123 Avatar
Posted By Mirza123
Thu Jun 25 2020, 04:07 PM
Wed Jun 17 2020, 09:42 PM
cerouno Avatar
Posted By cerouno
Wed Jun 17 2020, 10:37 AM
Wed Jun 17 2020, 02:01 AM
