Need help in GSM Coding (Assembly Language)
Discussion in "8051 Discussion Forum" started by Malik_Umair May 24, 2013.
Wed Jun 05 2013, 09:53 am
You do not have to call "ACALL SERIAL" just call it once when your main routine starts. Problem with interrupt is, You did not enable interrupts properly instead of loading IE directly you can enable individual bits that help you make things more readable
MOV IE, #00000100B ; instead of this ;use SETB EX0 ; interrupt for external interrupt 0 (INT0) SETB EA ; this is global interrupt flag
Wed Jun 05 2013, 10:00 pm
Thanks Ajay for pointing out the mistake, but unfortunately still on activation of interrupt 0, it is not going to interrupt routine. I have written the following command:
Also please guide me regarding the SMS receiving and storing it in accumulator? Is my receiving code good?
MOV IE,#10000001B ; EA enabled and INT0 enabled ;OR MOV IE,#81H
[ Edited Wed Jun 05 2013, 10:02 pm ]
Thu Jun 06 2013, 12:16 pm
I do not see a reason why interrupt does not come. Check if INT0 is going low or not. receiving sms is tricky in case assembly.
Thu Jun 06 2013, 08:46 pm
Tricky in what sense? The code which I have shared here does something but not perform full task. I have noticed that this code only reads the sms but is not copying it to accumulator. Also I want to inquire that if I send SMS containing 1 so is it a ASCII character or normal decimal number when received to the MCU?
Fri Jun 07 2013, 01:00 pm
anything coming out of modem will be ascii. I saw the way you implemented things. CMGR command sends lot of stuff not just the sms text. format is somewhat like:
+CMGR: 1, ... "mobile number" ...
sms text
OK
I suggest not to give delay after CMGR command, you will have to read every single byte coming out of modem. And comparing with 1 is not the right way.. coz as I said there is a lot of data that comes with CMGR command. there will be lot of 1s in it.
You can do something like, prefix and postfix your sms with a special character e.g. instead of sending just 1 in sms send "*1#" where * is a prefix and # is postfix. In your code, wait till you get * and then start to store the data to memory till you get # and then discard everything else.
sms text
OK
Malik_Umair like this.
Fri Jun 07 2013, 09:15 pm
Hello Dear Ajay,
I am very thankful to you the help you are providing me so far. I have modified a part of program you pointed out. Please view the updated program, please comment if you find any mistake in it. I have also deleted the delay after CMGR. The following is the program:
LCALL CMGR ; READ THE STORED MESSAGE ;LCALL DELAY1 ;LCALL DELAY1 ;LCALL DELAY1 ;LCALL DELAY1 ;************************************************************* MOV R1,#01H ; set a check to receive * when SMS is received RECV: JNB RI, RECV MOV A,SBUF CLR RI MOV B,A MOV A,R1 CJNE A,#00H,PROCEED SJMP COMPARE PROCEED: MOV A,B CJNE A,'*',RECV DJNZ R1, RECV COMPARE: MOV A,B CJNE A,'1', ERROR ; If TRUE then make P2.1 HIGH SETB P2.1 LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 CLR P2.1 SJMP DELETE ERROR: SETB P2.2 ; If FALSE then make P2.2 HIGH LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 CLR P2.2 CLR A ;********************************************************** DELETE: LCALL CMGD ; DELETE THE SMS STORED IN SIM LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 LJMP START
[ Edited Sat Jun 08 2013, 11:27 am ]
Sat Jun 08 2013, 02:00 am
I do not know if your code has errors, but I suggest this version
Hopefully it is simpler and easier to follow.
LCALL CMGR ;READ THE STORED MESSAGE WaitForStar: JNB RI,WaitForStar MOV A,SBUF CLR RI CJNE A,'*',WaitForStar WaitForCode: ;the next char is a command JNB RI,WaitForCode MOV A,SBUF CLR RI CJNE A,'1', ERROR ; If TRUE then make P2.1 HIGH SETB P2.1 Sjmp CommonExit ERROR: SETB P2.2 ; If FALSE then make P2.2 HIGH CommonExit: LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 CLR P2.1 CLR P2.2 LCALL CMGD ; DELETE THE SMS STORED IN SIM LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 LCALL DELAY1 LJMP START
Tags read sms modem assemblysms read gsm modem assemblyread sms using assembly
well I was thinking the other way..
this way you can even send long msgs like "*LIGHT1 ON#" or "*LIGHT1 OFF#" this will give you better control and makes more interactive with hardware.
MSG equ 70H ;place to store sms LCALL SMSREAD ; call to SMS read routine SMSREAD: LCALL READBYTE ;read character CJNE A, #'*', SMSREAD ; * receieved start reading SMS MOV R7, #15 ;read only upto 15 bytes MOV R0, #MSG ;load pointer READMSG: LCALL READBYTE CJNE A, #'#', STOREMSG SJMP MSGREADDONE STOREMSG: MOV @R0, A INC R0 ;next location DJNZ R7, READMSG MSGREADDONE: ;either you received # or ;15 character read, discard everything else ;process your msg here ;Read Byte routine READBYTE: JNB RI, READBYTE MOV A, SBUF CLR RI RET
Fri Jun 21 2013, 07:50 pm
Hello Ajay, I have planned it very earlier that once I am done I will post the entire project at this forum. Because this is the first forum where I have posted my problem and got helpful replies. Problem is I am still not able to receive the SMS and process the SMS. the sending portion of the code is perfectly fine and working. I will soon post the problem statement here.
