18F452+DS1820+HYPERTERMINAL
Thu Apr 25 2013, 07:11 AM
Hi, guys... I've upgraded my project from AT89S52 TO PIC ...
Lately i have implemented 2ds1820- using two Microcontroller pins - Read ROM command. i've attached the code....
Thu Apr 25 2013, 07:15 AM
And then using the received addresses i've implemented the Match Rom Command for a single IC and then implemented ConvTemp Command and ReadScratchPad Command using 1-wire, 2ds1820 IC. Here is the code attached.. I'm using MPLAB -PIC kit2 and xtal 12MHz....
ajay_bhargav like this.
Tags DS1820 interfacingDS1820 with PIC microcontroller1 wire protocol1 wire pic microcontrollerDS1820 digital thermometer pic microcontroller
Sun May 05 2013, 12:21 PM
I;m trying for searchRom command for 2 DS1820 1-Wire IC. i took the code from
http://pdfserv.maximintegrated.com/en/an/AN162.pdf
Customized it with my 12MHz xtal and Hyperterminal
But i am getting partial o/p.
i.e the two rom addresses with other values repeating every 240 bytes ...
I've attached the code as well as the o/p snapshot....
Mon May 06 2013, 09:44 AM
abdul991
Can you explain with example, coz nothing is understandable from screenshot you've posted.
Mon May 06 2013, 03:19 PM
in the snapshot the highlighted part is the actual ROM address i require.. But the display is continuous which i don't understand.. i altered the code a little bit and got the o/p as attached below.
Explaination for the search Rom :
See the concept is Search Rom command gives 64 bits of ds1820 rom address for each ds1820 IC connected on the 1 wire.
This 64bit is permanently stored in FndROM[3][8].
The procedure is as follows
1. Reset is done in Finddevices() and it calls to initialize in First().
2. First() initializes lastDiscrep = 0; doneFlag = FALSE; // will explain later
3. First() calls next().
4. Next() initializes few more variables // explained below.
5. mask bit k=1 used for storing the read bit in Rom[n] while securing other bits of that byte from getting altered.
6. m=1 is the bit counter. So total 65 bits has to be counted.
7. n=0 is the byte counter. Total 0-7 bytes. do-while() of the Next() exits if n>7, indicating that one DS1820IC has been detected.
8. O/p write bit is g. What g holds is written back to the 1-Wire, so that , the particular DS1820 IC's are 'alive' on 1-wire for the remaining bits to be read.
9. the nxt is used to return true/false value to the FindDevice(), if false is returned the search is ended/closed.
10. Every time the Next() is called – if there are DS-ic’s on 1-wire then 8-bytes are put in the ROM[] and then stored into the FndROM[][] inside the FindDevice().
11. So, when PIC sends F0 command, each 1-Wire™ device will returns the bit, and its compliment bit. That is for each 64 bits , two bits are read by PIC .
PIC reads each of these two bits as the 'And' result of the bit- each DS1820 puts on 1-wire.
12. if PIC reads 11 then no devices are present and Next() returns false.
13. if 01 is read, by PIC, all the DS1820 devices have 0 at that bit position.
14. if 10 is read, all the 1-wire devices have 1 at that read bit position.
15. if 00 is read, some DS1820 device have 0 and some have 1 at that bit position.
16. this 00 condition is the discrepancy condition, used to identify and narrow down the 1-wire devices.
17. from here it gets little tricky.
18. In this case(when 00 is read) if 0 is written back in g then those 1-wire devices which had ‘0’ in the bit position will remain alive in search loop inside the do-while in Next().
19. Value of x is also tricky but easy. You need to figure is out yourself.
20. Then for 00- case initially 0 is written back by PIC and descepMarker stores the latest bit position at which '00' case existed.
21. when Next() is called again, if 00 case occurs ,if descrepMarker == bitposition then ‘1’ is written back into g on the 1-wire. so that the DS1820 ic having '1' at this bit position is/are selected and remain alive.
22. Rest of the code is to be understood alone.
23. I've below posted the part when case '00' occurs (2nd else)
else // 1st else { // when this condition will never occur x=0. if(x> 0) // 01 or 10 condition g = x> > 1; // bit write value for search else // 2nd else 00 condition { // if this discrepancy is before the last // discrepancy on a previous Next then pick // the same as last time if(m<lastDiscrep) g = ((ROM[n]&k)> 0); else // if equal to last pick 1 g = (m==lastDiscrep); // if not then pick 0 // if 0 was picked then record // position with mask k if (g==0) discrepMarker = m; } // 2nd else is closed if(g==1) // isolate bit in ROM[n] with mask k ROM[n] |= k; else ROM[n] &= ~k; write_bit(g); // ROM search write m++; // increment bit counter m k = k<<1; // and shift the bit mask k if(k==0) // if the mask is 0 then go to new ROM { n++; k++; } } // 1st else closed }while(n<8); //loop until through all ROM bytes 0-7
[ Edited Thu May 09 2013, 07:58 AM ]
Wed May 08 2013, 04:20 AM
Trust me abdul, you've written quite a logic there. It becomes more and more complex as I keep on reading. And it needs time for me to understand
I am always in hurry when answering posts
right now I do not have any answer for your problem. But I might answer later.
Thu May 09 2013, 07:17 AM
k. no problem. its has complex logic.. i know for sure... i will clarify if any doubt is there in the code as best i can... But entire code cannot be explained...
Fri May 10 2013, 07:17 AM
RELAX..... AJAY... ITS COMPLETED.... 3 DS IC SEARCH ROM IS PERFECTLY WORKING AND IT CAN BE EXTENDED TO ANY NO. 1-WIRE DEVICES... HERE IS THE CODE ATTACHED...
AND YOU CAN TAG THIS POST AS-WELL....
REST OF THE CODE IS SAME AS EARLIER POSTED..
