Discussion in "Electronics" started by    sunil1990    Mar 8, 2011.
Tue Mar 08 2011, 04:50 PM
Hi friends.. i need one more help from you.. i needed IR sensor circuit diagram.. i am using IR sensor in my project. i have IR led and IR reciever.. using this how can i build circuit to get logic HIGH or LOW output.. pleaze mention circuit diagram.. see to that it should be as simplest as possible.. becuse as i said its a part of my project.. also distance may be 10 cm or so.. please spend some time for me... THANK you.....
Tue Mar 08 2011, 05:21 PM
@ sunil1990
where u want to use this circuit ru want to use this for interruption to detect someone is crossing the ir beam like room light controller project
Tue Mar 08 2011, 06:14 PM
yea buddy.. exactly for the same purpose... can you help please.. ?
Thu Mar 10 2011, 10:28 AM
sunil1990
I am also on the same task..the diode and phototransistor comes in different sizes like 3mm,5mm...
the blue or white one is Tx,Black one is Rx
in Tx: the longer pin(anode) must be connected to supply and shorter (cathode) to ground
in Rx: The longer one is emitter which must be grounded and the shorter one is collector which acts as output....
555 Timer is used as a pulse stretcher...
 sunil1990 like this.
Tags obstacle detection IRIR sensorir obstacle sensor
Thu Mar 10 2011, 10:54 AM
faiz_ahmed
Yeah always dont judge the pins with their lengths, it differs from mfrs to mfrs Try to check in with there respective datasheets.
Sun Mar 20 2011, 04:00 AM
[Topic moved to Electronics forum]
Sun Apr 11 2021, 02:48 PM
Harmancwt
only
Fri Apr 09 2021, 02:02 PM
Hong
Quality articles is the secret to interest the users to visit the site, that's what this web page is providing. christian dating sites https://datingsitesww.com
Fri Apr 09 2021, 03:53 AM
QGWIJ38V49HEBD3WXF www.web.de
I have a small question for you
Thu Apr 08 2021, 06:26 PM
Lilly
Post writing is also a fun, if you be familiar with afterward you can write otherwise it is complex to write. dating sim https://onlinedatingtind.com/
Thu Apr 08 2021, 12:35 PM
Fredericka Horn
Thanks, Fredericka Horn
Guests: 125, Members: 0 ...
