GSM MODEM with 8051
Wed Dec 01 2010, 07:16 AM
Hi mojaka,
Thanks for ur reply
Now how can i send index no(int data) to modem through same SMSString()function can i do.
Thanks for ur reply
Wed Dec 01 2010, 07:27 AM
hi kirangowle
i think int will not come because as u said that sim300 has 25 msg memory so index will not be more than 255
as index = atoi(&array[12]); will convert ascii into int so its better u not use this because when u send again it to modem then u again need it to make ascii
if(strncmp(array, "+CMTI", 5) == 0){ //Yes its a new message .. //Now lets read the index //we first have to truncate the array... to use string functions array[14] = '\0'; //coz array[12] and array[13] may contain your index SMSString( "AT+CMGR="); tx0(array[12]); SMSString( "\r");
[ Edited Wed Dec 01 2010, 07:32 AM ]
kirangowle like this.
Wed Dec 01 2010, 10:44 AM
Hi
From the guidance of mojaka and ajay, i have modified the code
And this is the function to read the notification of new msg.
The above code works partly.
It reads the new msg and displays correctly on LCD sometimes, and sometimes it doesnt goes into the loop itself.
I think msg should be sent at some particular time so that 8052 can able to read.
void main () { clear(); lcdinit(); lcdcmd(0x80); lcddata('K'); delay(10); init(); SMSString("AT\r"); // AT commands to initialize gsm modem delay(50); SMSString( "ATe0\r"); // turn off echo delay(50); SMSString( "AT&W\r"); // save settings delay(50); SMSString( "AT+CMGF=1\r"); // select text mode for sms delay(50); SMSString( "AT+CNMI=2,1,0,0,0\r"); // notification of new sms delay(10); //New msg indication. // +CMTI: "SM",3 while(1) { clear(); IE=0X90; // Enable serial interrupt delay(10); read_notification(msg1); IE=0x00; } }
void read_notification(unsigned char *msg) { unsigned char array[15],i,index_no; i=0; do { msg++; i++; }while(*msg!='+' && i!=15); // to check for first '+'. i=0; do { array[i]=*msg++; i++; }while(*msg!='\n' && i!=15); // Check for new line. if(strncmp(array, "+CMTI", 5) == 0) { array[14] = '\0'; IE=0x00; lcdcmd(0x80); lcdstr("NEW MSG");// Just for indication. delay(50); SMSString("AT+CMGR="); tx0(array[12]); SMSString("\r"); IE=0x90; delay(80); read_text(msg1,rec_no,time_date); delay(100); } return; }
Wed Dec 01 2010, 11:52 AM
do little modification here and try again
do some more experiments try coding in different methods
unsigned char a; // should be global clear(); SMSString( "AT+CMGF=1\r"); // select text mode for sms delay(50); while(1) { SMSString( "AT+CNMI=2,1,0,0,0\r"); // notification of new sms IE=0X90; // Enable serial interrupt delay(100); //New msg indication. // +CMTI: "SM",3 a=read_notification(msg1); if(t==1) // means new message arrive and need to display { t=0; SMSString("AT+CMGR="); tx0(a); SMSString("\r"); IE=0x90; delay(1000); read_text(msg1,rec_no,time_date); } IE=0x00; clear(); delay(100); } }
unsigned char read_notification(unsigned char *msg) { unsigned char array[15],i,index_no; i=0; do { msg++; i++; }while(*msg!='+' && i!=15); // to check for first '+'. i=0; do { array[i]=*msg++; i++; }while(*msg!='\n' && i!=15); // Check for new line. if(strncmp(array, "+CMTI", 5) == 0) { array[14] = '\0'; IE=0x00; lcdcmd(0x80); lcdstr("NEW MSG");// Just for indication. delay(50); return ((array[12]); } }
Thu Dec 02 2010, 09:39 AM
Hi
I tried in different combination's its coming, but some time unable to read the new msg notification. So i enabled the serial int all the time without disabling it, then also no desired result.
while(1) { SMSString( "AT+CNMI=2,1,0,0,0\r"); // notification of new sms delay(10); IE=0X90; // Enable serial interrupt delay(100); read_notification(msg1); clear(); delay(50);
I think i am doing some wrong. what abt the clear() function,
If suppose new msg indication occurs when the processor is in clear fn.
then the content of msg1[] would be different from "+CMTI".
void read_notification(unsigned char *msg) { unsigned char array[15],i; i=0; //clear(); IE=0x90; do { msg++; i++; lcdcmd(0x80); lcdstr("InLoop1"); }while(*msg!='+' && i!=5); // to check for first '+'. i=0; do { array[i]=*msg++; i++; }while(*msg!='\n' && i!=15); // Check for new line. if(strncmp(array, "+CMTI", 5) == 0) { array[14] = '\0'; IE=0x00; lcdcmd(0x80); lcdstr("NEW MSG"); delay(50); SMSString("AT+CMGR="); tx0(array[12]); SMSString("\r"); IE=0x90; delay(100); read_text(msg1,rec_no,time_date); }
Thu Dec 02 2010, 01:51 PM
hi kirangowle
change a little here
tell me 1 thing is modem response automatically when new message come or 1st we send AT command then it response mean every time is first we issue a command to it that notify me or just we issue it once in start up after that it response automatically as new message come clear my this point
if it response automatically then it=f it is in clear function then error expected but if it response only when AT command issue then clear will not disturb it
while(1) { SMSString( "AT+CNMI=2,1,0,0,0\r"); // notification of new sms IE=0X90; // Enable serial interrupt delay(500); read_notification(msg1); clear(); delay(50);
Thu Dec 02 2010, 03:42 PM
The way you're reading SMS is obviously not a good method and there are 90% chances of loosing an SMS.
Best way...
check for new message indication in interrupt itself.
e.g.
Best way...
e.g.
//You need two variables and a constant, one for storing constant string, //second for an index pointer and a buffer to store recieved data unsigned char code Response[] = "+CMTI"; unsigned char MyBuff[15], i = 0; //we can also have a flag for new message bit NewMessage = 0; //consider this ISR function //assuming ch is read character from SBUF if((ch == Response[i]) || (i > 4)){ //if received character is there in Response or i is > 4 which means // you already have the right string... if(ch != 0x0D) { // 0x0D means data received.. //Store received data MyBuff[i++] = ch; } else { //seems like we have recieved our data //Now stop and indicate that new message has received MyBuff[i] = '\0'; NewMessage = 1; //do not forget to reset i :) i = 0; // no more errors.. } } else { //there is a miss match //reset counter i = 0; } //Now in main loop you can just wait for New message flag while(!NewMessage); NewMessage = 0; //Parse MyBuff, get the index and read message :)
Tags reading sms from gsm modemreading sms using 8051gsm modem read sms codegsm modem sms reading using interrupt
Thu Dec 02 2010, 03:55 PM
hi Ajay Bhargav
ur coding skills r great
i always like ur way of coding
u do a complex with simple one
i glad that i am here with this lovely company of experts
Fri Dec 03 2010, 07:49 AM
@ Mojaka,
without sending the AT commands Modem sends new msg indication.
@ Ajay,
Like this u wanna me do.
In this, why we have to check for carriage return(0x0D).
@ Ajay,
void serial () interrupt 4 { unsigned char ch; while(RI==0); ch=SBUF; if((ch == Response[k]) || (k > 4)){ //if received character is there in Response or k is > 4 which means // you already have the right string... if(ch != 0x0D) { // 0x0D means data received.. //Store received data MyBuff[k++] = ch; } else { //seems like we have recieved our data //Now stop and indicate that new message has received MyBuff[k] = '\0'; NewMessage = 1; //do not forget to reset k :) k = 0; // no more errors.. } } else { [blockquote] msg[abc]=ch;// Not the msg indication, then store the msg.[/blockquote] abc++; k = 0; } RI=0; }
hiabcwelcome like this.
