Discussion in "8051 Discussion Forum" started by    shawn    Oct 8, 2007.
Mon Oct 08 2007, 06:57 AM
Hi,
I just bought a AT89C2051 MicroController and can't seem to find a programmer that supports it. I"ve tried Keil Uvision3, Flip (all versions), and WinISP. If anyone know a program that works fairly well with this microcontroller, also versions, that would be a great help.
Thank you.
Mon Oct 08 2007, 07:58 AM
AT89C2051 is not an ISP so FLIP or winISP will not support it.
here are some programmers which are often used for the programming...
Hardware: http://www.kmitl.ac.th/~kswichit%20/easy1/easy.htm
Software: http://www.kmitl.ac.th/~kswichit%20/ez4/ez4.html
PCB: http://www.kmitl.ac.th/~kswichit%20/easy1puiu/easyp12.htm
Just try google and look for AT89C2051 Programmer. you will get many of them
Tags AT89C2051 programmer
Tue Oct 09 2007, 02:25 AM
I have tried EZdownloader(all versions) but the ports available is limited. The only options for the earlier version is port 1-4, but the port my serial is on is port 9. Version 4 has a search option, but yet it doesn't detect it. I"m using an RS-232 to USB, so the USB is acting as a serial port.
I've already googled for programmers, but have found none that works.
If anyone know of another one, or maybe something with EZ downloader that I don't now about,
Please let me know.
Thank you,
Tue Oct 09 2007, 10:59 AM
talk to the guy who created the software tell him about your problem and ask for the source code. I think they are using Borland Delphi for making the softwares... or ask for notes on how to make this loader software in VB. so i can help you with it..
Thu Jun 11 2020, 06:27 AM
anudee
scena
Tue May 19 2020, 10:29 PM
Sat May 02 2020, 07:38 PM
Tamu Gurung
Wed Mar 25 2020, 01:39 PM
Tajammul
Fri Mar 13 2020, 10:36 PM
Guests: 105, Members: 0 ...
