Automatically sending of SMS via Nokia 3310
Fri Oct 05 2007, 08:20 AM
I don't think you've read the code properly.. did you add the components as described in the code? Like buttons, textboxes forms etc...?
Fri Oct 05 2007, 07:39 PM
yes.. i did all what it said in the code.. but it doesn't work
what should i do?
Fri Oct 05 2007, 08:12 PM
well it worked with me...
anyways i am attaching the VB project.. check it out
Fri Oct 05 2007, 08:19 PM
download it from here...
Nokia FBUS SMS and PDU Utility Code and Notes
[ Edited Fri Oct 05 2007, 08:21 PM ] Tags nokia FBUS SMSnokia pdu converternokia 3310 send sms using VB
Sat Oct 06 2007, 07:39 AM
hi again ajay
what does this means?
IMPORTANT: PLEASE CHANGE THE MSCOMM1 SETTINGS ACCORDING TO THE COM PORT AVAILABLE ON YOUR PC.
i dont understand it.. can u explain it to me..
thank u again..
thank u again..
Sat Oct 06 2007, 11:31 AM
check your device manager to see the name of your serial ports....
in some pcs you will find lots of com ports available....
com1
com2
com3...etc.... mostly happens when u are using laptops with bluetooth and wi fi....
so do confirm the name of your com port at which the f-bus cable is to be connected...... :-)
com1
com2
Sat Oct 06 2007, 08:19 PM
9600,n,8,1 this is the default settings on my com1.. do i have to change it?
Tue Oct 09 2007, 11:00 AM
ajay..
still not working..
what does this means..
set different FBUS sequence number..
help me please..
still not working..
help me please..
