Discussion in "Project Doubts" started by    sankalp_s    Nov 30, 2014.
Sun Jan 31 2016, 12:17 am
#71
CALL ALLON
CLR L1
CLR L2
CLR L3
CLR L4
CALL DELAY ;delay to see leds off
CALL ALLON
CALL DELAY ;add a delay to see all leds on
Sorry sir this logic is not working, this logic has changed the pattern. like blinking pattern.
I have tried this method, it's working fine but taking too much space.
I think problem is ALLON instruction.
 DESGN8: ;
                CALL DELAY
                CLR L1
                CLR L2
                CLR L3
                CLR L4
		SETB L5
		SETB L6
		SETB L7
		SETB L8
		SETB L9
		SETB L10
		SETB L11
		SETB L12
                CALL DELAY
                CLR L2
                CLR L3
                CLR L4
                CLR L5
	        SETB L6
		SETB L7
		SETB L8
		SETB L9
		SETB L10
		SETB L11
		SETB L12
		SETB L1
                CALL DELAY
                CLR L3
                CLR L4
                CLR L5
                CLR L6
		SETB L7
		SETB L8
		SETB L9
		SETB L10
		SETB L11
		SETB L12
		SETB L1
		SETB L2
                CALL DELAY
                CLR L4
                CLR L5
                CLR L6
                CLR L7
		SETB L8
		SETB L9
		SETB L10
		SETB L11
		SETB L12
		SETB L1
		SETB L2
		SETB L3
                CALL DELAY
sir can you code this in any other method?
[ Edited Sun Jan 31 2016, 12:21 am ]
Sun Jan 31 2016, 12:27 am
#72
You need to explain exactly what you want the code to do.
for example
All LEDs on for 2 seconds
All LEDs off for 1 seconds.
All LEDs on for 2 seconds.
All LEDs off for 3 seconds.
Sun Jan 31 2016, 01:10 am
#73
for example
I want...
example...
ALL LED ON
LED 1,2,3,4 OFF REST LED ON
THEN LED 2.3,4,5 OFF REST LED ON
THEN LED 3,4,5,6 OFF REST LED ON
......... LIKE THIS.
after removing ALLON instruction it's working fine, so what can be alternet way by using less memory.
[ Edited Sun Jan 31 2016, 01:19 am ]
Tue Feb 02 2016, 05:55 am
#74
sankalp_s
Earlier in the thread I suggested using tables to create the output.
I think that is the best method, but good use of sub routines
will save a lot of code.
Build long patterns from shorter patterns.
Wed Feb 03 2016, 12:56 am
#75
will save a lot of code.....
Build long patterns from shorter patterns....
Sir I didn't understand that. Could you explain above lines in different way?
and 2nd question is, can we look more to rectify the existing code?or should be dump?
thank u sir
[ Edited Wed Feb 03 2016, 12:59 am ]
Thu Feb 04 2016, 09:40 am
#76
sankalp_s
Create short runs that turn LEDs on or off.
Then stick them together to form complicated patterns.
eg
 OFF4:   ;turn LEDS off 1 at a time
                CLR L1
                CALL DELAY
                CLR L2
                CALL DELAY
                CLR L3
                CALL DELAY
                CLR L4
                CALL DELAY
                ret
 ON4:   ;turn LEDS on 1 at a time
                SETB L1
                CALL DELAY
                SETB  L2
                CALL DELAY
                SETB  L3
                CALL DELAY
                SETB  L4
                SETB  DELAY
                ret
;next section does a lot with very little extra code
FIRSTLOOP:
  call  ON4;
  call OFF4;
  call  ON4:
  call OFF4;
  call  ON4:
  call OFF4;
  call  ON4:
  call OFF4;
  ret
;next code does 4 times as much with hardly any more code
  call FIRSTLOOP:
  call FIRSTLOOP:
  call FIRSTLOOP:
  call FIRSTLOOP:
sankalp_s
If you want to keep creating new sequences, then I would dump your
code and use tables to control the patterns.
If you just want to get your display working
fix the code you have.
There should be enough memory for a good display if you
re-use the sequences as I described above.
[ Edited Sat Feb 13 2016, 04:36 am ]
Thu Feb 11 2016, 11:58 pm
#77
Hello phil sir finaly i'm dumping my code, now i'm learning table method,
now plz tell me how to add next pattern, can give me example with 2 pattern, it will be very help full to learn.
second thing is how can i design table for more pettern,
for example,
pattern1:
0,0,1,1,1,1,1,1,1,1,1,1
1,0,0,1,1,1,1,1,1,1,1,1
1,1.0,0,1,1,1,1,1,1,1,1
where 0= led off
1 = led on
please give some example to create different pattern.
and last one. how can i use that mode function with this table method.
thank you sir.
Sat Feb 13 2016, 04:34 am
#78
Try this program.
Let me know if it makes sense to you.
 sankalp_s like this.
Mon Feb 15 2016, 01:32 am
#79
Try this program.
Thank you very much sir this program is easy to understand and learn also, now i can understand display pattern.
But i have some queries:-
I) how can i write design pattern in this way eg. db 1,0,2,0,4.....
II)mirrorbyte instruction is not working(it display only in one direction), can we use mirrorbyte instruction for separate design and why we r using of long delay in the code?
III)no of repetition of pattern like this instruction.
MOV R3, #05 ;REPEtion of pattern
D9: CALL DESGN9
DJNZ R3,D9
and
MOV R3, #12
D8:		CALL DESGN8
                        JNB P3.5,D8(how to use this)
			DJNZ R3,D8
[ Edited Mon Feb 15 2016, 11:36 pm ]
Wed Feb 17 2016, 05:43 am
#80
sankalp_s
Great..
sankalp_s
Your pattern is 12 bits wide, so work in rows of 16 bits
The lines below are the same.
dw 1111111100000000b
dw 0ff00h
db 0ffh,0h
db 255,0
sankalp_s
I have attached a program that does mirroring.
The long delay is just to separate the sequences.
D9: CALL DESGN9
DJNZ R3,D9
It is just a case adding loops to the code,
I'm sure you will work it out.
