GreenBee Project
Sun Apr 11 2010, 05:50 pm
Sun Apr 11 2010, 05:53 pm
The Modifications are:
1. The HUMIDITY Output is given to the 8052 instead of the ADC.
2. The EOC of the ADC not activated from the 8052, instead the EOC ( pin 3.3 in 8052) is used as HUMIDITY freq. input.
3. The code might Look awkward as i didn't knew proper way of applying the Delays.
Sun Apr 11 2010, 06:05 pm
are you sure about circuit?
coz and please provide support to students who try your circuit.
Sun Apr 11 2010, 06:13 pm
I'm very much Sure abt the circuit.
Do you think is any thing wrong ?
As i mentioned i only changed the HUMIDITY sensor, so there can only be related problems with CODE.
The entire circuit is INTACT.
THE EOC goes off giving room for the HUMIDITY sensor.
Thats it.
i would love to let share my little experience with this project but i dont suppose there would be any need of me. i mean i know Very little
Thank You very much for the Support.
Thats it.
![](../../images/emotes/FBemote/smile.png)
Sun Apr 11 2010, 06:26 pm
well then do one thing.. create a neat diagram for humidity sensor coz from the circuit its hard to make out pinwise connection of sensor as sensor image is not labelled properly.
make humidity sensor as a box with lines as pins and label them properly. so its easy for anyone to understand it.
Sun Apr 11 2010, 06:50 pm
that is great
thats all i needed.
if possible, can you take LCD picture during working? just if possible for you only then. otherwise its all fine.
good work again!!
good work again!!
![](../../images/emotes/FBemote/cool.png)
